Old 10-05-2020, 03:26 AM   #1
Asshat
Asshat's Avatar
Pulling motor question
Just wondering how you guys do this, with the head still on or removed. I just could not get enough lift with this engine hoist. Had to remove the head to lift the motor high enough to roll the truck back.
Was hoping I could put the entire motor together before I dropped it back in, but I don’t think that’s going to work. Would be even better if I could bolt the trans up to it too, and drop everything together.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 10-05-2020, 05:26 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Pulling motor question
You could let the air out of the front tires, or take the front tire and wheel assemblies off and put the suspension on blocks, like 2 by 4s, at the lowest (safe) point.
~Steven
Simi Valley, CA
Old 10-05-2020, 07:47 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Or you could take the front end off.
Old 10-05-2020, 09:25 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
I didn't want to scare him off! It's easier at the factory, because the frame is less body.
Asshat (need a real name here, buddy!) did you remove the hood?
~Steven
Simi Valley, CA
Old 10-05-2020, 09:57 PM   #5
Asshat
Asshat's Avatar
Wink Re: Pulling motor question
Yes, hood is removed.
BTW, my name is George.
292, 4-speed
Old 10-06-2020, 10:14 AM   #6
slorio
slorio's Avatar
Easiest way is to pull front end from firewall forward. I believe it is 12 bolts if you do it this way.
Regards
Steve
New Orleans
slorio is offline   Reply With Quote
Old 10-06-2020, 10:50 AM   #7
jayoldschool
Moderator
If you have ALMOST enough lift, just take the wheels off and set the truck on the ground.
jayoldschool is offline   Reply With Quote
Old 10-06-2020, 11:09 AM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
Did you have the boom on the hoist extended all the way out? It will sometimes add more lift. As long as you don't exceed the weight limit.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-06-2020, 11:52 AM   #9
Asshat
Asshat's Avatar
Yes.
Maybe I need a better hoist.
292, 4-speed
Old 10-06-2020, 02:54 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Pleased to meet you, George!
~Steven
~Steven
Simi Valley, CA
Old 10-06-2020, 03:31 PM   #11
cwcarpenter98
cwcarpenter98's Avatar
You might be able to gain some extra height if the chain for your hook is bolted in as high up as you can get it to the hoist. I had to do that on my Dakota when the hoist was hitting the top of the garage door frame and the oil pan wasn't clearing the core support.
Also, try to use as short of a chain as possible (without damaging any critical components) to connect from the hook to the engine
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-21-2020, 03:55 PM   #12
Asshat
Asshat's Avatar
So, I can remove the from section with pulling the fenders?
292, 4-speed
Old 10-21-2020, 04:33 PM   #13
Asshat
Asshat's Avatar
I'm wondering if I should go through the trouble of removing the front, so I don't have to go through the trouble of installing the tranny from the bottom. Then again, I'm not sure if my hoist will even clear the front body with the head on the motor. Another thing, I don't want to have to install the head on the block with the motor in the truck.
Only way to do this would be to buy a bigger engine hoist. Damn!
Anyone know what the weight of the motor is with the tranny?
292, 4-speed
Old 10-21-2020, 04:54 PM   #14
geezer#99
geezer#99's Avatar
Motor and trans maybe 700 lbs.
Old 10-21-2020, 05:05 PM   #15
Asshat
Asshat's Avatar
OK - Thanks.
After looking at it, I think my hoist will get the motor over the body, even with the head installed. However, I don't know if I could get the motor AND tranny over the body, cuz I don't think the boom is long enough.
Well, worst case, I'll just install the tranny the old-fashioned way.
292, 4-speed
Old 10-21-2020, 05:07 PM   #16
geezer#99
geezer#99's Avatar
Helped a guy once put a 235 in his 56 truck. Couldn’t lift it high enough due to low ceiling height in his little garage. Dropped the front down by bleeding all the air out of the tires.
Couldn’t roll it outside as there was 3 feet of snow by the door.
We layed the motor and trans down flat on the floor on the drivers side. Picked it up flat like that. Cleared the sheet metal and barely missed the roof. Set it gently down in the engine bay On blocks. Adjusted the chains and uprighted it gently into position. Worked like a charm.
Sometimes you gotta think outside the box!
Old 10-21-2020, 05:18 PM   #17
Asshat
Asshat's Avatar
You're right!
Guess I'll just have to get it all assembled and hoist it up. No guts, no glory!
292, 4-speed
Old 10-21-2020, 05:24 PM   #18
geezer#99
geezer#99's Avatar
Be careful.
You get that much weight up high it wants to tip over.
You got a pic of your hoist?
Old 10-21-2020, 07:14 PM   #19
Asshat
Asshat's Avatar
Be careful.
I think it’s a 2-ton hoist.
292, 4-speed
Old 10-21-2020, 07:41 PM   #20
geezer#99
geezer#99's Avatar
Should be plenty big enough.
Old 10-23-2020, 11:39 AM   #21
The Rocknrod
Moderator
I had a custom GMC panel once (see sig) and removed the engine for a re-cleanup. It was nerve racking. Just remember - 2 tons with the arm retracted, should have numbers on the tube for weights. Hey it's been done by many before so...
"You can do it Luke"
Old 10-23-2020, 11:48 AM   #22
REDROCKER652002
I personally like the idea of removing the front of the truck. If not the whole thing, at least the bumper, radiator and all that stuff. Then you have a clean path to where you need to be without having to deal with fender alignment after you are done. Just my .02. Gonna try that when my son decides and get's his motor all worked out.
REDROCKER652002 is offline   Reply With Quote
Old 10-23-2020, 11:52 AM   #23
Asshat
Asshat's Avatar
I did remove the radiator and bumper, just not sure if I want to go to the trouble of removing the front body parts.
292, 4-speed
Old 10-23-2020, 12:24 PM   #24
The Rocknrod
Moderator
It's up to you really. I just didnt want to fight it. And I could crawl in to do the wiring etc. since it's all custom. The only bolt on the front that just a little out of the way are the top fronts that attach the core support to the fender. But once you do them one time it's all good.
Old 10-23-2020, 03:00 PM   #25
Desert dog
Not sure if its applicable here, but when I install an engine tranny combo in an MGB I raise the rear of the car on jack stands to help with the angle needed to clear everything.
Desert dog is offline   Reply With Quote
