#126 |
![]() Join Date: Jan 2015
Re: The Vandal. 1957 "Big glass" 3100 restomod.
My friend you are just now seeing the light at the end of the tunnel. take a month or two off and give your self a break, you got most of all the hard work done. you will get the itch again. it will pay off, I promise you my brother you've come to far to walk away. we'll talk soon bud
#127 |
heck yeah, don't stop now! that little lady is turning out seeeexxxy.
i enjoy the build as much or more than the driving/use. some bits more than others. like paint, HARD pass ![]() |
#128 |
I found a little motivation. Made a bracket for the Dakota Digital boxes and some relays. Don't know yet what I need relays for, but they're there if I need them.
![]() Installed and wired. ![]() Got the dash stuff all wired up. I'm going to install the wiper switch in the hole left of the gauges. The cable wasn't long enough, so I will have to extend it. ![]()
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#129 |
Like the bracket and look of everything. I am only ib the beginning of my 57 Big Back Window build but yours has plenty of ideas. Look forward to the rest of the build. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#130 |
BigGlass weekend update: Let's build a PCM/TCM bracket.
Starting with sheet steel. ![]() Bead rolled, and bent. ![]() PCM mounts to one side. ![]() TCM mounts on the other side. ![]() Mounted on the inner fender. ![]() ![]() ![]() I decided to pull the inner fender and weld on another mounting tab on the bottom edge. ![]() ![]() Powder coated and installed. ![]() ![]() ![]()
#131 |
Looks like a decent location for the PCM. Will keep in mind when I am to that point. Looking good. Steve
#132 |
Glad to see you back on it bud. lookin good!
#133 |
Thanks, guys. It will be a month before I get back at it again.
#134 |
I found some garage therapy time this week.
I blasted and sprayed the exhaust manifolds with Cerakote. I was hoping for gloss, a little disappointed, but the still look good. ![]() ![]() I got the engine harness sorted out. Everything is laid out, hot wires extended for a relay box. ![]() Made a bracket for the relay box ![]() Where it's going to get installed: ![]() ![]() Back to wiring..
#135 |
Manifolds look good. I get concerned on how long before it burns off. I also like your electronics mounting spot. That is the side my pcm/relays will go. Steve
#136 |
Thats where GM put them, so I'm did the same. I know a lot of guys try to put them in the cab, but I wasn't interested in pulling bundles of wire through the firewall. Sooner or later I have to decide what wires to pull through the firewall and start drilling.
#137 |
![]() Join Date: May 2007
man this just gets beautifuller and beautifuller. nice work!
#138 |
really coming together. lookin REALLY nice
#139 |
Thanks guys. Trying to get the last few wiring parts figured out and ordered. So close to putting heat in this engine
#140 |
![]() Join Date: Mar 2007
Looking good. I see you are using shrink bands in place of hose clamps. I love those. If you wipe them with lacquer thinner the part #'s that are printed on them come right off. Maybe I'm too anal, but I always do that to mine.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#141 |
Yep, just haven't gotten to that yet.
#142 |
#143 |
brought her back to life, sounds good bud
#144 |
Wow that sounds good! Borla’s?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#145 |
booooo mufflers
![]() sounds proper! |
#146 |
Sounds and looks great.
#147 |
Magnaflow. Over the winter I will build a stainless exhaust with cats and x-pipe.
#148 |
#149 |
Looks really good. Black takes a ton of work...
Marc
#150 |
