Old 04-15-2021, 11:05 PM   #1
Greasey Harley
Greasey Harley's Avatar
Does this look like a 5" drop?
I recently swapped my 2" POL rear springs and 2" blocks:
2.5/4 drop
for CPP 5" rear springs:
3.5/5 drop
As you can see, there is a dramatic difference in ride height. The new springs put the bump stops directly on the U-bolts:
I hacked the bump stops and It's drivable (in fact it handles great), but it sure seems lower than 5".
Originally, this truck had well over 6" of rear travel.
Thoughts?
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 04-15-2021, 11:24 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Does this look like a 5" drop?
I have 6" drop springs and I have approximately 1" of clearance between the bumpers and the u-bolts.
pjmoreland is offline   Reply With Quote
Old 04-15-2021, 11:31 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You need to add an adjustable track bar to re-center the rear axle.
Also rear shock relocators and drop shocks will improve ride quality.
Keith
Convert to disc brakes.
Old 04-15-2021, 11:32 PM   #4
Greasey Harley
That seems correct. Not sure what's going on with my springs?
Done and done.
Old 04-16-2021, 06:34 PM   #5
CC69Rat
CC69Rat's Avatar
Your pinion needs about 3-4 degree adjustment too, it will hold down the driveline vibes at freeway speeds. I also second what Keith suggested. Have you considered C Notching it? It looks like (to me) those springs might be kinda soft ? Ex. overll spring rate? I have Belltech 5" springs in my 67 and it's not that low. Mine is Cnotched but still, it's not that close to the frame.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-16-2021, 08:45 PM   #6
Greasey Harley
Originally Posted by CC69Rat View Post
Your pinion needs about 3-4 degree adjustment too, it will hold down the driveline vibes at freeway speeds... .
I was just driving 80mph with no vibration, but I will look into pinion angle correction, thanks for the tip.
I also second what Keith suggested...
Shocks, relocators and adjustable track bar is already done.
I ain't notchin' my frame, just not my thing.
not sure about the spring specs. They are CPP -5" springs. I need the truck to set about 1 to 1.5" higher in the rear and I'm open to suggestions on springs.
I am looking for a quality set of -4" springs, and If it sets a little high, I still have 1" blocks I could put back in.
The new springs do set 3/4" higher on the passenger side than the driver side...so that's good
Old 04-16-2021, 09:42 PM   #7
CC69Rat
CC69Rat's Avatar
On the rear height 3/4" difference, what you're seeing is called "Chevy Lean". The real issue is the drivers front. That side is 3/4" lower than the pass side and it kinda makes the pass rear kick up a little. Think "see saw" from one side to the other diagonally across the truck. If the drivers side front sits 3/4" lower then the pass rear will sit that same amount higher.
Belltech makes a spacer to correct it. Google Chevy Lean and you'll see a bunch of write ups on it. Every truck I've ever dropped has it. From S10s, Squares, 67-72, I have a dropped Blazer 4 door too. They all lean.
Good luck with it man. Later.
Chad
Old 04-16-2021, 10:05 PM   #8
Greasey Harley
Perhaps I should double check and make sure the passenger front spring is properly seated, I swapped all four springs at the same time. If it's properly seated, I'll swap left for right and reevaluate. If that doesn't fix it I'll look at spacers. It didn't lean before I swapped the springs. I'll check it out, thanks.
