Old 04-16-2021, 09:42 PM   #1
CC69Rat
CC69Rat's Avatar
Re: Does this look like a 5" drop?
On the rear height 3/4" difference, what you're seeing is called "Chevy Lean". The real issue is the drivers front. That side is 3/4" lower than the pass side and it kinda makes the pass rear kick up a little. Think "see saw" from one side to the other diagonally across the truck. If the drivers side front sits 3/4" lower then the pass rear will sit that same amount higher.
Belltech makes a spacer to correct it. Google Chevy Lean and you'll see a bunch of write ups on it. Every truck I've ever dropped has it. From S10s, Squares, 67-72, I have a dropped Blazer 4 door too. They all lean.
Good luck with it man. Later.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-16-2021, 10:05 PM   #2
Greasey Harley
Greasey Harley's Avatar
Perhaps I should double check and make sure the passenger front spring is properly seated, I swapped all four springs at the same time. If it's properly seated, I'll swap left for right and reevaluate. If that doesn't fix it I'll look at spacers. It didn't lean before I swapped the springs. I'll check it out, thanks.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
