Old 12-02-2021, 10:43 PM   #51
cjohnson6772
cjohnson6772's Avatar
Re: QA1 install on my Sons Truck. (Pics)
Originally Posted by 1970 CST Short Wide View Post
Moved the front up 1/4 inch. All is well
Been too busy with the technical questions to comment, but that is a beautiful truck!
cjohnson6772 is offline   Reply With Quote
Old 12-03-2021, 01:35 AM   #52
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thank You. Just ordered widened rear tubs, I must have wider tires in the rear. Time will tell where this goes. LOL
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-03-2021, 05:45 AM   #53
LakeAnna
LakeAnna's Avatar
Looks good and I bet it rides nice now!
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 12-03-2021, 06:43 AM   #54
3767
When u get the wider rear tubs n place then you will go even more down the rabbit hole and get the wider front tubs ….lmao. Looks like 315’s and forged rims are n the future 4 you.
3767 is offline   Reply With Quote
Old 12-08-2021, 04:34 PM   #55
cst350
cst350's Avatar
I just finished installing the rear kit for stock trailing arms. Rides way better than my last set-up of Ridetech RC shocks @ 6" ECE lowering springs. I will say that once you get to the part of the instructions that say "some trimming may be required to fit brackets onto stock arms" take a deep breath! I'm the type that troubleshoots with a scalpel rather than a chainsaw. I stated with a grinder and ended with a sawzall. Took a lot of passes (a little bit at a time) to get the brackets on. Then when I went to bolt on the Coil-over bracket the bolts hit the TA and I had to trim some more. Would be great if QA-1 had some templates to show how to trim. Now that it's all together I am stoked so all the work and headache was worth it.
cst350 is offline   Reply With Quote
Old 12-08-2021, 04:46 PM   #56
1970 CST Short Wide
Senior Moment
Nice. If you add the QA Sway Bar it will improve even more
Pittsburg Ca
94565
