#1 | |
Senior Moment
![]() Join Date: Mar 2002
Re: QA1 install on my Sons Truck. (Pics)
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Senior Moment
Thank You. Just ordered widened rear tubs, I must have wider tires in the rear. Time will tell where this goes. LOL
Looks good and I bet it rides nice now!
When u get the wider rear tubs n place then you will go even more down the rabbit hole and get the wider front tubs ….lmao. Looks like 315’s and forged rims are n the future 4 you.
I just finished installing the rear kit for stock trailing arms. Rides way better than my last set-up of Ridetech RC shocks @ 6" ECE lowering springs. I will say that once you get to the part of the instructions that say "some trimming may be required to fit brackets onto stock arms" take a deep breath! I'm the type that troubleshoots with a scalpel rather than a chainsaw. I stated with a grinder and ended with a sawzall. Took a lot of passes (a little bit at a time) to get the brackets on. Then when I went to bolt on the Coil-over bracket the bolts hit the TA and I had to trim some more. Would be great if QA-1 had some templates to show how to trim. Now that it's all together I am stoked so all the work and headache was worth it.
