Old 12-27-2021, 10:01 PM   #1
Bandit130
Bandit130's Avatar
To replace or not, rear brake cylinders
I replaced rear brake cylinders, with the front also, in July 2015 when I got truck. The rear shoes were pretty good at the time. Will be replacing brake shoes and not sure if the cylinders should be replaced this time. By the time I get to it, they will almost be 7 years old. Haven't done a complete rear brake job in many years. Thought I may need to go ahead and replace, but wanted opinions.
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 12-28-2021, 12:40 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: To replace or not, rear brake cylinders
Unless they are leaking there is no need. Just keep an eye on them.
Unless you have a spare set in your toolbox or money is no object, that is.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-28-2021, 08:26 AM   #3
chrismoore701
chrismoore701's Avatar
What he said
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-28-2021, 10:09 AM   #4
geezer#99
geezer#99's Avatar
You don’t need to replace the cylinders (maybe), but you should inspect them. Easy to pull them apart in place and check the bore. Use a piece of super fine emery cloth and give them a quick clean.
If you find any excessive pitting you should get new ones.
Old 12-28-2021, 12:35 PM   #5
Dead Parrot
How old is your rear brake hose?
Take lots of pictures before you start.
Dead Parrot is offline   Reply With Quote
Old 12-28-2021, 08:11 PM   #6
Bandit130
Bandit130's Avatar
I do not know how long since they have been replaced, or if ever. I did not replace the rears in 2015.
Mopar by Birth
Chevy by Choice
