Old 12-30-2021, 08:41 AM   #1
tutone
tutone's Avatar
Measurement PLEASE. K10 cab bushing height
Hey guys, I need someone to measure a fairly fresh cab bushing spacing from the solid frame mount to the cab floor. Front and back. One side is fine. Reason is, I set my cab on the frame , just to get it out of the way, and it is rocking on my xfer case at the center brace behind the high hump hole. I may not have a problem, and again I may. Thanks.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 12-31-2021, 05:18 AM   #2
Richard
Re: Measurement PLEASE. K10 cab bushing height
Sorry you have not had any response. Will get you some measurements tomorrow later in the day. I installed mounts purchased from Classic Hearteat (Wes). Note the mounts I had originally installed from LMC were to short by 3/4"- to 1". Not any interference though. Have seen on the forum that this is not uncommon. Owned a K-20 and currently a K-10 I am working on now myself. From what I understand K10, K20 and C20 rear mounts are al the same. Only the C-10 rear cab mounts are different.
Richard
Old 12-31-2021, 09:37 AM   #3
tutone
tutone's Avatar
Thank you. I have a set of bushings, (unopened), and since I swapped this over to a different case, I am thinking I have clearance issues. My bed is perfectly aligned so if the cab works out. Im good.
:My build thread
Old 12-31-2021, 10:57 AM   #4
72again4x4
72again4x4's Avatar
Tutone,
Hope these help. Let me know if you need a different angle or measurement.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 12-31-2021, 10:59 AM   #5
72again4x4
72again4x4's Avatar
Also, I haven’t measured floor to mounts or cab brace yet. My bolts may be loose which may cause these measurements to be slightly off.
Roger
Old 12-31-2021, 12:27 PM   #6
tutone
tutone's Avatar
Thank you sir. My cab mounts are in the correct place so no further measurements required. I assume that after replacing your bushings with these, you are happy with cab to bed alignment. Otherwise, you would be like me searching for the right height. I will cut spacers to that height and slip them in to see if I do in fact have a problem. Seeing the 2 5/8 measurement on the back gives me hope.
:My build thread
Old 12-31-2021, 12:30 PM   #7
72again4x4
72again4x4's Avatar
Yes sir, cab sits nice and no movement when I work on it. I may tighten down a turn or two still. Glad I could help.
