Rear brake bleeder screw
So I recently decided to do some R&R on my rear brakes.
(New center rubber hose, new wheel cylinder, brake shoes and hardware.) Mostly due to me never servicing them since I've had the truck. Its an 1985 Chevy k20 3/4 with 13 inch drum 2.5" brake shoes. Now for the life of me I cannot find the part number for the "Speed Bleeder" for the rear, I have them for the front. I want to eventually replace the front rubber hoses along with the brake calipers along with the MC. There is nothing really wrong with the brake system, but I figured if i have to replace one part and it affects the rest, why not do it all and put it under the "MAW" category Might As Well. I'm hoping some one has switched to the speed bleeders for the rear and has the part # handy. Thanks in advance Memo
Memo S. Retired US Marine Family Man |
![]() Join Date: Dec 2009
Re: Rear brake bleeder screw
Is this what you are looking for?
I found the part # on Russell's site. Link:http://russellperformance.com/mc/spe...ruck-suv.shtml 79-87.- C-10/20 Pickup Front disc /639580 - Rear drum/639520 Hope this helps.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Speed Bleeders are one time use for me. I can never get them to work a year later.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Try this tip if there stock or the speed bleeder are sizing. A small dab of Grease or Vaseline on one of your fingers, spared it on to top & nut thread part of the bleeder make sure there is 2mm-4mm thick. Reply about every 6months if to dry or has washed off. Just clean with a clean paper towel before doing adjustment's or work on it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#5 | |
Moderator
![]() Join Date: Oct 2008
I'm not sure that GM put them on stuff in the 70's & 80's my vehicles never had them when I got them. I picked up bleeder caps off the German vehicles, mostly VW, in the salvage yards and put them on my American iron back then. The bugs, hippie vans, fastbacks, Rabbits, etc all usually had them. The ATE caps that look like this seem to put up with the environment better than some others.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Thanks to everyone for the replies
I think I found the set inwas looking for now to replace the MC, both front calipers and brake line hoses hopefully my helper doesn't give up on the painful "pump 3 times and hold" repeat 10309504 times.
Moderator
Pressure pot
https://www.summitracing.com/parts/m...+5ba288cdce529 Master Cylinder adapter https://www.summitracing.com/parts/m...+5ba288eeaff1b
| Bookmarks |
| Thread Tools | |
| Display Modes | |
