Ididit column steering wheel options.
Hi guys,
I just got my Ididit column and now need to decide on a wheel. I prefer the originals but that doesn’t seem to be in the cards. Ididit states that their columns are for 69 and newer gm wheels. So for those that have done this swap what did you use? Thanks for any input, Bob. |
![]() ![]() ![]() Join Date: Jan 2018
Re: Ididit column steering wheel options.
I haven't messed with the Ididit columns, but other fellers here have.
Check out this link: https://67-72chevytrucks.com/vboard/...ghlight=Ididit
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
The retro line of Ididit allows you to use your original steering wheel.
Odd, I have a retrofit column and called Ididit. Per their tech people the column is designed for 69’ and newer gm wheels. They stated that I might get lucky and an earlier wheel would work but it wasn’t all that likely that I wouldn’t end up with a large gap between the wheel and column. Evidently the taper on the shaft below the splines is different post 68’. Sure enough mine had an unsightly 1/2” gap when mounted.
I just went up and double checked, my original wheel does fit the retro line column.
You will need to buy the wheel adapter kit to fill in the gap between the wheel and column. YouTube Installation Video: https://www.youtube.com/watch?v=eVRJrvkPATU&t=424s ![]() ![]()
#6 | |
It's Better With Nitro
The splines are the same. I used my deluxe steering wheel (58-61 Biscayne, El Camino, etc.)
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
