Old 05-14-2022, 02:22 PM   #1
Bobby B.
Ididit column steering wheel options.
Hi guys,
I just got my Ididit column and now need to decide on a wheel. I prefer the originals but that doesn’t seem to be in the cards. Ididit states that their columns are for 69 and newer gm wheels. So for those that have done this swap what did you use?
Thanks for any input,
Bob.
Bobby B. is offline   Reply With Quote
Old 05-14-2022, 04:58 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Ididit column steering wheel options.
I haven't messed with the Ididit columns, but other fellers here have.
Check out this link: https://67-72chevytrucks.com/vboard/...ghlight=Ididit
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 05-14-2022, 05:47 PM   #3
61hawk
61hawk's Avatar
The retro line of Ididit allows you to use your original steering wheel.
61hawk is offline   Reply With Quote
Old 05-15-2022, 12:39 AM   #4
Bobby B.
Odd, I have a retrofit column and called Ididit. Per their tech people the column is designed for 69’ and newer gm wheels. They stated that I might get lucky and an earlier wheel would work but it wasn’t all that likely that I wouldn’t end up with a large gap between the wheel and column. Evidently the taper on the shaft below the splines is different post 68’. Sure enough mine had an unsightly 1/2” gap when mounted.
Old 05-15-2022, 10:47 AM   #5
61hawk
61hawk's Avatar
I just went up and double checked, my original wheel does fit the retro line column.
You will need to buy the wheel adapter kit to fill in the gap between the wheel and column.
YouTube Installation Video: https://www.youtube.com/watch?v=eVRJrvkPATU&t=424s
Old 05-15-2022, 02:42 PM   #6
Bobby B.
Thank you! I didn’t realize they sold a spacer like that. I’ll try it!
Old 05-17-2022, 09:19 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
The splines are the same. I used my deluxe steering wheel (58-61 Biscayne, El Camino, etc.)
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
