Old 12-09-2022, 04:22 PM   #251
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: My winter project
If those seals ever come loose, this will do the trick. Much stronger than the regular 3m stuff.
Tom Vogel is offline   Reply With Quote
Old 12-09-2022, 04:45 PM   #252
7D2N
7D2N's Avatar
Thanks, Jim.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 12-09-2022, 04:53 PM   #253
7D2N
7D2N's Avatar
Tom I used the 3M, and seems to stick good but I had it everywhere. I will give that a shot if I have problems.
Old 01-18-2023, 10:23 PM   #254
7D2N
7D2N's Avatar
Fitting the carpet and cutting holes has taken a lot of time.
Old 01-19-2023, 08:25 PM   #255
jaros44sr
jaros44sr's Avatar
Awesome work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-05-2023, 11:22 PM   #256
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Gonna have this puppy ready for the national show in Salt Lake at end of June?
Old 04-06-2023, 08:24 PM   #257
7D2N
7D2N's Avatar
Tom won't make it, still a ways out. I'm in sanding the old paint off and some bodywork stage. I plan to paint myself because of the cost. I did put a fuel tank skid plate on, it didn't have one to start with but I had it so.. think it needs one.
Old 05-08-2023, 08:24 PM   #258
7D2N
7D2N's Avatar
I got the heat stove on, sometimes just little details.
Old 05-09-2023, 07:27 PM   #259
jaros44sr
jaros44sr's Avatar
Great job, I always enjoy watching your attention to detail
SAFETY FIRST
AS usual, off topic
Jim
Old 06-17-2023, 08:34 PM   #260
7D2N
7D2N's Avatar
Thanks, Jim, I moved it out and dusted it off. I was bored and don't have a bunch of dollars for chrome plating interior pieces so for now I painted it (chrome) yes I know but I had to know how it would turn out.
Old 06-17-2023, 08:45 PM   #261
7D2N
7D2N's Avatar
Another one.
Old 06-17-2023, 11:19 PM   #262
72gmguy
72gmguy's Avatar
Chrome paint looks pretty good in the pictures!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 11-07-2023, 09:05 PM   #263
7D2N
7D2N's Avatar
Very small update: bodywork stuff so it takes me a long time. I did get epoxy on.
Old 11-07-2023, 09:11 PM   #264
7D2N
7D2N's Avatar
Few more.
Old 12-04-2023, 09:35 PM   #265
7D2N
7D2N's Avatar
I started setting some trim pieces in place, all the original holes were welded so should drill new holes or try the adhesive clips? I have read some stuff about the stick-on kind but has anyone had luck with them?
Thanks guys.
Old 12-05-2023, 10:04 PM   #266
7D2N
7D2N's Avatar
I have been working on my wing windows. I'm pleased with how it went with the new seals.
Old 12-19-2023, 08:56 PM   #267
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Thanks guys.
All the new vehicle trim is affixed with tape. I don't think you need worry. What's the worst that could happen? If it comes loose, then drill. I think you'll be fine.
Old 12-19-2023, 09:53 PM   #268
notsolo
notsolo's Avatar
I think the 3m VHB double sided tape is what you need. Have you restored any trim? Any ideas how to get dents out etc....
notsolo is offline   Reply With Quote
Old 12-20-2023, 08:31 AM   #269
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: My winter project
That anodized aluminum trim is a huge PITA to restore. It get cloudy with exposure, dent and scratches easily. About the only restoration you can do with them is apply new woodgrain tape to them and repaint the black if they are otherwise nice. I have seen guys strip the anodizing off, then polish the aluminum to a high shine. Without the anodizing in place, the trim will dull easily just with the ambient humidity.
Fortunately, there are a lot of NOS trim out there for most of the sections. The hardest ones are the Blazer specific forward quarter panel pieces.
Mar-K makes good repro trim if you can't locate NOS.
As for the retention of these, I would stick with the OEM steel clips, either the threaded or push in variety depending on location. Some locations on the trim used the plastic adhesive clips, mostly in the middle of the longer side trim such as the door and quarter panel pieces.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-20-2023, 09:20 PM   #270
7D2N
7D2N's Avatar
Thanks Tom, I was thinking the stick on would be easier to work with but didn't want it to fall off driving.
Notsolo, I haven't tried to restore trim pieces just using driver quality stuff the repo stuff is expensive.
1970 thanks my concern was drilling holes and the trim not lining up.
Old 01-21-2024, 01:17 PM   #271
7D2N
7D2N's Avatar
Well, I've been putting off the door repairs, finished welding the cracked hinge area and the screw holes I will get the filler going.
Old 01-21-2024, 01:34 PM   #272
Spf79
Spf79's Avatar
So much work!
Looks great! I wish I was better at body work. I would have saved myself a fortune.
I read about your dilemma on the side trim. I went to ebay and purchased extra plastic adhesive pieces, and I ordered some more small black screws that match the original screws. I plan on going the adhesive tape/screw route at this point.
Although, since you are still in body work, you could make some Cardboard or Construction paper templates of the trim with the holes marked on the paper & drill them like that? They would be easy to tape to the body & line up.
Have a good day, looking forward to the next update!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 01-21-2024, 07:02 PM   #273
NDM
Do you have a photo of the cracks? I want to see it it is the same area as mine.
NDM is offline   Reply With Quote
Old 01-25-2024, 10:41 PM   #274
7D2N
7D2N's Avatar
I'll have to look, this is the finished repair of the cracks.
Old 01-25-2024, 10:55 PM   #275
7D2N
7D2N's Avatar
I started the filler and sanding.
