![]() Join Date: Oct 2012
shock problem
So I ordered a new set of shocks for my 66. The front ones fit fine but the rear ones have a bigger hole where the bolt goes through them. I dont want to drill out my bracket. Is there a piece I could get to put in the hole to fit my original bolt or does someone have an idea?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: shock problem
With all due respect, this often happens when mail ordering. No way to compare the new part to the old before making the purchase.. This is why I never recommend mail ordering as a first source. My recommendation?? The shocks you ordered are wrong. Something as simple as replacing shock absorbers shouldn't require making modifications to the vehicle. Return them for a refund.. Take one of the old shocks to your local parts supply.. Tell 'em what you have and what you want. Compare the two before shelling out the money...
Re: shock problem
I definitely wouldn't modify the brackets if there was a quick/easy solution.
As @RustyPile mentioned, I would be verifying the parts you received as being correct as my first step. That being said, depending on the OD of the bolt & the ID of the eye 'sleeve' on the new shock, you might be able to source a spacer/shim to allow using the bolt you have. https://www.mcmaster.com/products/sp...ded-spacers-5/
Re: shock problem
100 years ago when I was a young man, when J C Penney had auto centers, I installed a million shocks. (A little exaggeration). Some of the shocks came with a shock mounting kit because the original lower stud was a different size. Go to Jegs and search (lower shock mount kit). They have a lot of different sizes. Of course after you make sure you have the right shocks.
Re: shock problem
something like this at Jeg's. A web search will bring up a lot more. Good luck.
Rear Shock Stud Kit [1973-1987 GM C10] UMI Performance 6494 Part Number: 236-6494 UMI Performance Rear Shock Stud Kit [1973-1987 GM C10] Rear Shock Stud Kit 1973-1987 GM C10 Zinc Plated 4140-Steel Stud Contents for (1) Shock Includes (1) Upper Stud, (1) Lower Bolt, (3) Nuts, (4) Washers View Details $14.99 Ships Today Lowest Price Guarantee |
Re: shock problem
Thanks guys that is what I was looking for
