#126 |
Re: 67-72 Suburban OE seats
#127 |
BlahBlahBlah
The picture of the huge gas tank under the seat and the seat above it with the ashtrays on the arm rests makes me laugh. Probably was never a problem, just seems funny the engineers thought, where can we put more gas?
#128 |
Do some 3/4 2nd row seats only have two rear brackets while some have four?
#129 | |
Woody |
#130 |
Thanks move had two also but I’ve seen pics of four
Posted via Mobile Device |
#131 |
![]() ![]() Join Date: Sep 2008
Has anybody bought an original style 72 Cheyenne scroll interior for a Suburban lately?
My son in law wants and interior for Christmas.
#132 | |
I think the two rear brackets va four relates to if seat was equipped with middle seatbelt on spid
#133 | |
Woody |
#134 | |
========================================== Miles 1972 GMC Suburban K15 - Custom Deluxe |
#135 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Blazers/Jimmies received a rear seat that had two rear mounting brackets in the 72 model year whereas earlier examples made use of four brackets. For the 72 examples with the two bracket style, the center belt attachments are directly to the floor pan with angled "gooseneck" rubber boots to cover the hardware.
I speculate the Suburban seats received a similar design change for 72 wherein the center two brackets were eliminated but I've not researched that.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#136 | |
#137 | |
I started out with nothing - and I still have most of it |
#138 |
don't know if this helps or not but...
71 K20 two row burb factory installed full width middle seat ![]() unknown year full width middle seat I got from Adam in Riverside for my K1500
#139 |
KB My uncle that had breakfast with us lives near Adam.
#140 |
wish I was closer, he has a lot good trucks out there, had a half dozen burbs even an old tow truck..
only problem is they're not all for sale LoL but always enjoy part pickin with Adam, really nice guy.. he's hooked me up pretty good a couple of times
#141 |
So saw a couple guys ask, but not a for sure answer. Does a front seat cover work on the full length middle bench? Bought a 71 and the seats need a major rework.
#142 |
Ok bringing this back to the top for a quick question. I’m having some difficulty sourcing a wide second row seat for the 70 suburban I’m working on. I have a couple of front seats available and the second row seat brackets. Is it possible, or rather, how difficult is it to modify a front seat to use as the second row utilizing the correct 2nd row brackets? Is it just a matter of welding on some flat plate with captured nuts to the seat frame where the brackets and armrests bolt onto the frame?
#143 | |
The Older Generation
Sellers Code of Conduct 67-72chevytrucks.com I. All for sale or trade ads must include the price. If you do not know the price of the item(s) you are selling, then you should do some research. Absolutely no auctions or bids. V. For sale or trade items must be listed in the appropriate category. Please list items only once, no cross posting or the ads will be deleted. Thanks, LockDoc, Moderator
#144 |
Hey guys
My second row seat is not matching up to the holes that are in the support cross member. At one point the seat bolted up to an axillary gas tanks. Centered in the cab. Now I want to bolt the seat to the left side (offset so kids can get in the 3rd row) There are two sets of hole in the cross member. Straight stamp holes and holes with a weld nut. Welded nut holes put the seat center of the cab. How do I get my seat off set. |
#145 |
I have a second row gas tqnk if you want to put it back in
#146 | |
Uh
Was your Burban a three row truck from the factory? It should be indicated on the SPID. The welded nuts on the crossmember reflect what seat layout the truck was ordered with. As far as I know GM didn't install crossmembers with weld nuts for both seat configurations. Does your 3rd row seat have the factory style crossmember? I believe the under seat aux tank was a dealer installed item only. So there would be variations in how they were installed. That being said I don't believe anyone has ever documented how those tanks were installed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 08-14-2023 at 06:44 PM. Reason: Removed stupid part. |
#147 | |
So both my rear seats are 50” seats. I looked SPID and it just says rear seat option. But if the weld nuts are factory placement then it goes in the middle. The rear plywood is not drilled for the 3rd seat. The rear seat I have also had 70-72 upholstery. Maybe they were swap out at the dealer when the gas tank went in???
#148 |
It looks like your SPID shows the 2 row seat code A53 and not the A80 3 row code.
It's likely that as you said the seat was swapped. Does the underside side of the seat look factory compared with other short seats posted in this thread? It may be that they also modified the mounts to fit over the tank. It may be worth posting a new thread asking if anyone has an under seat tank installed in a factory three row truck and how much room is allowed for access to the 3rd row. Maybe folks could provide measurements to compare. I looked at this truck last year and I remember it was a factory 3 row with the under seat tank. The picture sort of shows how much access is available.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 08-19-2023 at 12:46 PM. |
#149 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located HERE If you need any further assistance with that please contact any Administrator for help. Last edited by LockDoc; 02-13-2026 at 11:08 PM. |
#150 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located HERE If you need any further assistance with that please contact any Administrator for help. Last edited by LockDoc; 02-13-2026 at 11:09 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
