Question on bbc, reverse rotation wp, and Vintage Air
My engine uses a Stewart Warner aluminum reverse rotation water pump, and has no bypass hose from the intake to the pump. (No port at all for one either)
So do I need to make a bypass, or an "H" between the two heater hoses on the Vintage Air? (It completely shuts off the coolant flow with a motorized valve) The stock heater allowed coolant through the heater core at all times...it just didn't let the air pass through it, and blow heat into the cab...but the flow still remained.
"If it ain't broken, fix it 'till it is!" |
![]() Join Date: Dec 1999
Re: Question on bbc, reverse rotation wp, and Vintage Air
The A/C trucks used a vacuum operated shut off valve in one of the heater hoses. I would not worry about it if original type block. If an LS style motor, fwiu there should be flow at all times.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
My truck was a no AC truck.
Was also a factory bbc, but that engine was replaced with a heavily modified GM 572. And now I'm adding Vintage Air AC...which shuts the coolant flow off so there is no flow through the heater hoses. And this engine does not have the short little bypass hose from the front of the intake manifold, to the top of the water pump.
#4 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-25-2023 at 10:58 AM. Reason: Drill size |
I don't like the vintage air valve. I don't understand why vintage air doesn't copy the valve that old air uses. Anyway, I am using a manual version of the old air valve with a choke cable to operate it.
https://www.oldairproducts.com/produ...s-heater-valve |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
