10-02-2023, 05:58 PM | #4251 | |
Re: What did you do to your truck today.The 3rd chapter
At what point does an overbored 327 become a 350?
10-02-2023, 06:09 PM | #4252 |
never because the stoke is different between them. 327s have a 3.25 inch stroke vs the 350's 3.48 inch. Rods/bore/pistons are the same only real difference is the crank and that little change makes a world of difference.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
10-02-2023, 06:28 PM | #4253 |
Installed my bumper, rechromed. That's the second time it was rechromed, my mom got it for my birthday early 90s, and soon after I ruined it because the frame had the wrong brackets combined with I probably tightened the brackets first, or something else wrong
It's a rare frame, rare doesn't mean desirable, though it's a SWB. OEM brackets for this are so rare, replacements don't fit despite they saying otherwise. GMs shorter inner brackets were the closest. We modified those and the outer brackets too. For what worth, who knows if it's right...Real close good enough? The bracket rear surfaces are 8” behind the frame rails. The bumper’s top is 8/10” behind the bed’s body located below the taillight bezels, and 4/10” below the bezel’s phillips screw center. GM designed a nice product. The bumper's top outer edge and the lower side molding's top outer edge are plumb. Painter has the license plate bracket, optioned for argent silver and a clear coat. My front bumper is pending, would you believe they gave me an imposter? Yeah. I marked the original along with a difference in grains made that obvious. They "found" it and are now "rushing it". They at least texted their goof supported by lots of pictures. The imposter even has part numbers stamped on the back. Wrong numbers and unless I'm mistaken, original bumpers aren't stamped at all, they only had a GM sticker.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-02-2023 at 07:39 PM. |
10-02-2023, 07:24 PM | #4254 |
10-02-2023, 11:04 PM | #4255 |
Location: Herculaneum MO (20 minutes south of St. Louis
Pistons can't be the same
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
10-03-2023, 12:03 AM | #4256 |
Got the bench seat in today with the 3 point seat belts.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
10-04-2023, 09:28 AM | #4257 |
same bore, wrist pin location is the main difference between them. You could potentially use a 350 piston with a 327 crank if you used a shorter rod.
10-04-2023, 09:36 AM | #4258 |
Some progress has finally been made. Got the seat back from the upholstery shop
10-04-2023, 10:34 AM | #4259 | |
Also don't you have that assbackwards? You would need a longer rod.
10-04-2023, 11:32 AM | #4260 |
I do have it backwards, my morning coffee had not kicked in yet. The pin location is the only real difference in the piston design outside of the pop up/flat top/dish. I was taking the measurement in my head from the bottom skirt to the pin instead of from the top of the piston down like you should.
10-05-2023, 12:57 PM | #4261 |
Installing a vintage air front runner serpentine kit on my 496
10-05-2023, 03:42 PM | #4262 |
Looks great! Where did you source your seatbelts if you don't mind me asking....?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-06-2023, 12:24 AM | #4263 | |
Very happy with the products.
Sam 1972 C10 LWB 2020 Z71 Tahoe Last edited by samkost; 10-06-2023 at 12:37 PM. |
10-06-2023, 11:15 AM | #4264 |
Thanks for the intel!
10-06-2023, 06:35 PM | #4265 |
After a couple more test drives to chase down a rattle and squeak,
I installed the door panels.
10-07-2023, 04:13 PM | #4266 |
Installed the front bumper guards.
Thanks go to member PbFut for the advice.
10-08-2023, 07:05 AM | #4267 |
very nice truck.
10-13-2023, 10:55 PM | #4268 |
Today made more progress on my new 327 for my truck. Got the bottom end all buttoned up and got the heads on. Im excited to see how the heads run. This motor had 69 Z/28 2.02 heads on it. Stainless valve, screw in studs, guide plates, and some very heavy port work. Should be alot more peppy than the old 350 motor in the truck currently.
10-14-2023, 12:03 AM | #4269 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-14-2023, 04:46 AM | #4270 | |
10-14-2023, 06:10 PM | #4271 |
Active Member
We finally got new tires and wheels on the old girl.
I never get tired of this look! |
10-15-2023, 10:52 AM | #4272 |
Lost the farm truck ride Friday..... front stabilizer bar off of a 2500 took care of that. I kinda miss that old truck "float". No going back at this point. Gonna try dropping it >JUST< 2" all around see how I like it.
10-16-2023, 01:48 PM | #4273 |
I found this nice temperature gauge in a spare cluster I had in my garage. The text is still green, and the hot range marker still has some orange to it. I plan on installing it in place of the one in my truck that is sun-bleached white, so I painted the needle.
10-17-2023, 05:22 AM | #4274 |
Good job, Pat. That's exactly how I did the Speedo and Gas needles on mine. I mighta used Krylon instead, but it's the same regulation color.
10-20-2023, 07:12 PM | #4275 |
Weather held off long enough today here to wheel the motor out and get it all painted. Pretty much done with it until I get the motor and trans out of the truck to start swapping stuff over.
