Old 10-02-2023, 05:58 PM   #4251
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by CAMAROBOY68SS View Post
Got my 327 block back from the machine shop and now the actual process of putting it together will begin to start the winter project of pulling the 350 and 4 speed out of the truck for this 327 and a tkx 5 speed for more fun next spring.
Cool.
At what point does an overbored 327 become a 350?
Old 10-02-2023, 06:09 PM   #4252
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Originally Posted by '68OrangeSunshine View Post
Cool.
never because the stoke is different between them. 327s have a 3.25 inch stroke vs the 350's 3.48 inch. Rods/bore/pistons are the same only real difference is the crank and that little change makes a world of difference.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 10-02-2023, 06:28 PM   #4253
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Installed my bumper, rechromed. That's the second time it was rechromed, my mom got it for my birthday early 90s, and soon after I ruined it because the frame had the wrong brackets combined with I probably tightened the brackets first, or something else wrong
It's a rare frame, rare doesn't mean desirable, though it's a SWB. OEM brackets for this are so rare, replacements don't fit despite they saying otherwise. GMs shorter inner brackets were the closest. We modified those and the outer brackets too. For what worth, who knows if it's right...Real close good enough? The bracket rear surfaces are 8” behind the frame rails. The bumper’s top is 8/10” behind the bed’s body located below the taillight bezels, and 4/10” below the bezel’s phillips screw center.
GM designed a nice product. The bumper's top outer edge and the lower side molding's top outer edge are plumb. Painter has the license plate bracket, optioned for argent silver and a clear coat.
My front bumper is pending, would you believe they gave me an imposter? Yeah. I marked the original along with a difference in grains made that obvious. They "found" it and are now "rushing it". They at least texted their goof supported by lots of pictures. The imposter even has part numbers stamped on the back. Wrong numbers and unless I'm mistaken, original bumpers aren't stamped at all, they only had a GM sticker.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-02-2023, 07:24 PM   #4254
pjmoreland
pjmoreland's Avatar
Sweet!
pjmoreland is offline   Reply With Quote
Old 10-02-2023, 11:04 PM   #4255
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Pistons can't be the same
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 10-03-2023, 12:03 AM   #4256
samkost
samkost's Avatar
Got the bench seat in today with the 3 point seat belts.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 10-04-2023, 09:28 AM   #4257
CAMAROBOY68SS
same bore, wrist pin location is the main difference between them. You could potentially use a 350 piston with a 327 crank if you used a shorter rod.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 10-04-2023, 09:36 AM   #4258
wpsharpshooter
Some progress has finally been made. Got the seat back from the upholstery shop
wpsharpshooter is offline   Reply With Quote
Old 10-04-2023, 10:34 AM   #4259
67 twins
So not the same at all.
Also don't you have that assbackwards? You would need a longer rod.
Chris
Old 10-04-2023, 11:32 AM   #4260
CAMAROBOY68SS
I do have it backwards, my morning coffee had not kicked in yet. The pin location is the only real difference in the piston design outside of the pop up/flat top/dish. I was taking the measurement in my head from the bottom skirt to the pin instead of from the top of the piston down like you should.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 10-05-2023, 12:57 PM   #4261
Speedracer39
Speedracer39's Avatar
Installing a vintage air front runner serpentine kit on my 496
Speedracer39 is offline   Reply With Quote
Old 10-05-2023, 03:42 PM   #4262
OregonNed
OregonNed's Avatar
Looks great! Where did you source your seatbelts if you don't mind me asking....?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-06-2023, 12:24 AM   #4263
samkost
samkost's Avatar
Bench seat cover and seat belts are from forum member t korinik.
Very happy with the products.
Sam
1972 C10 LWB
2020 Z71 Tahoe
Old 10-06-2023, 11:15 AM   #4264
OregonNed
OregonNed's Avatar
Bench seat cover and seat belts are from forum member t korinick.
Thanks for the intel!
Old 10-06-2023, 06:35 PM   #4265
samkost
samkost's Avatar
After a couple more test drives to chase down a rattle and squeak,
I installed the door panels.
Sam
1972 C10 LWB
2020 Z71 Tahoe
Old 10-07-2023, 04:13 PM   #4266
samkost
samkost's Avatar
Installed the front bumper guards.
Thanks go to member PbFut for the advice.
Sam
1972 C10 LWB
2020 Z71 Tahoe
Old 10-08-2023, 07:05 AM   #4267
mr.mud1
mr.mud1's Avatar
very nice truck.
mr.mud1 is offline   Reply With Quote
Old 10-13-2023, 10:55 PM   #4268
CAMAROBOY68SS
Today made more progress on my new 327 for my truck. Got the bottom end all buttoned up and got the heads on. Im excited to see how the heads run. This motor had 69 Z/28 2.02 heads on it. Stainless valve, screw in studs, guide plates, and some very heavy port work. Should be alot more peppy than the old 350 motor in the truck currently.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 10-14-2023, 12:03 AM   #4269
3757chevy
3757chevy's Avatar
Nice
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-14-2023, 04:46 AM   #4270
'68OrangeSunshine
That's a purty lil' engine C-Boy. She purrs still in pieces.
Old 10-14-2023, 06:10 PM   #4271
RonWT
Active Member
RonWT's Avatar
We finally got new tires and wheels on the old girl.
I never get tired of this look!
RonWT is offline   Reply With Quote
Old 10-15-2023, 10:52 AM   #4272
MS66
MS66's Avatar
Lost the farm truck ride Friday..... front stabilizer bar off of a 2500 took care of that. I kinda miss that old truck "float". No going back at this point. Gonna try dropping it >JUST< 2" all around see how I like it.
MS66 is offline   Reply With Quote
Old 10-16-2023, 01:48 PM   #4273
pjmoreland
pjmoreland's Avatar
I found this nice temperature gauge in a spare cluster I had in my garage. The text is still green, and the hot range marker still has some orange to it. I plan on installing it in place of the one in my truck that is sun-bleached white, so I painted the needle.
Old 10-17-2023, 05:22 AM   #4274
'68OrangeSunshine
Good job, Pat. That's exactly how I did the Speedo and Gas needles on mine. I mighta used Krylon instead, but it's the same regulation color.
Old 10-20-2023, 07:12 PM   #4275
CAMAROBOY68SS
Weather held off long enough today here to wheel the motor out and get it all painted. Pretty much done with it until I get the motor and trans out of the truck to start swapping stuff over.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
