Old 08-28-2020, 10:52 AM   #26
66C10LB
Re: 1966 C10 LB 2wd 283 4spd build
Originally Posted by SCOTI View Post
x2. Very nice!
Thank you.
66C10LB is offline   Reply With Quote
Old 08-28-2020, 10:52 AM   #27
66C10LB
Originally Posted by 88Stanger View Post
nice work so far!!
Thanks 88Stanger
Old 09-07-2020, 05:52 PM   #28
66C10LB
Just about to weld the rear of cab outer flange. The original had an upside down 5 stamped on it plus an upside down cross. Has anyone else seen something similar? I am deciding whether or not to duplicate this by stamping it on the new piece.
I will be using copper backing plates held on by cleco in order to make welding easier and keep things lined up.
Old 09-07-2020, 06:00 PM   #29
66C10LB
...copper backing plates fastened with cleco
Old 09-07-2020, 07:01 PM   #30
roll_the_dice
roll_the_dice's Avatar
Just found your thread...nice build...fearless on the welding work! I wish I was that fearless.
roll_the_dice is offline   Reply With Quote
Old 09-08-2020, 02:34 PM   #31
The Rocknrod
Moderator
The Rocknrod's Avatar
Heck I just wish I could weld.
Old 09-08-2020, 03:03 PM   #32
66C10LB
I'm about to find out if I can still weld.
Old 02-15-2021, 03:14 PM   #33
66C10LB
Have finished the rear flange of the cab by bead rolling the shape of the patch panels, welding new metal onto the inside rear floor, using Cleco fasteners to hold copper backing behind the welds, then plug welding the flange (copper rich weld-through primer used in the plug welded flange).
Old 02-15-2021, 03:24 PM   #34
66C10LB
Decided to replace the inner/outer, firewall/kick panel edges. Used bending brake then shrinker/stretcher to form the bend.
Old 02-17-2021, 06:26 PM   #35
88Stanger
88Stanger's Avatar
nice work!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 11-29-2021, 01:46 PM   #36
66C10LB
I have the cab on its nose so that I can finish tidying and detailing the bottom. Created weld-on nuts for the seat bracket bolts by taping a rectangular block similar to the original style. Backed up butt welds where needed and cleaned up. Removed the goopy tar undercoating from the few areas that are original steel. Fabricated a replacement reinforcing plate at the back of the transmission opening, flanged on bead roller to match the shape of the cab floor (not the same as original, but instead modified so that moisture and mud will no longer collect) and added weld-on nuts.
Old 12-01-2021, 08:50 PM   #37
65truckowner
65truckowner's Avatar
Looks good doing good work
65truckowner is offline   Reply With Quote
Old 12-01-2021, 10:22 PM   #38
66C10LB
Thanks 65truckowner Slowly getting there.
Old 12-06-2021, 06:53 PM   #39
Snowbound
Snowbound's Avatar
Looking good! I gotta pop over there some day to check it out!
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 12-06-2021, 09:10 PM   #40
66C10LB
PM sent
Old 07-11-2022, 10:31 PM   #41
66C10LB
Just doing the last thing on the cab, repairing the A-pillars. After repair, internal frame coating sprayed inside.
Old 07-15-2022, 03:00 AM   #42
66C10LB
And onto the other A-pillar. Used a piece of welding rod as a filler so that I could remove a bit more material to get to clean metal and also served to adjust the gapping slightly. Will weld this 16g patch piece at a higher heat to melt it all nicely together. The drip rail piece will be plug welded on later.
Old 07-15-2022, 07:01 AM   #43
Braunschweiger
Great work, clever details, will be great
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 07-30-2022, 12:45 PM   #44
66C10LB
Pfew. Finally got the passenger outer door skin in good shape. Good lesson for me. It's not easy to keep things straight and maintain the curvature of the panel when doing the full bottom straight across like that. Used copper backing plates attached by clecos. Welded with slowly applied and spaced tacks. Still had to get creative with hammer/dolly methods (using a hitch ball and scissor jack inside the door as "dollys"). Pushed out low spots with my makeshift dollys and hammered, off dolly method, on high spots. Filled in pin holes and cleco holes. . Got it quite close ...1/16 or so. Thinking absolute perfection is not possible so hopefully acceptable using bit of filler and high-build. I left the left and right ends unwelded for final flange hammer/dolly and panel alignment/flatness.
Old 08-02-2022, 10:43 AM   #45
Duncan K
Looks like a great fit! Can I send you mine? lol
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 09-18-2022, 06:57 PM   #46
66C10LB
Getting down to some details.... driver's side grill support edge. Bending brake, bead roller with stepping dies, v-slits, stretcher, shrinker zillion times, bend, twist, hammer, cajole. Finally can cut old metal and fit.
Old 09-19-2022, 12:58 PM   #47
Duncan K
That is some seriously nice work! Can't imagine the time it would take to make that
66 GMC 910
Old 10-18-2023, 09:23 PM   #48
66C10LB
Boyd Tank and Modified Hagan filler for inner bedside....
Old 10-18-2023, 09:32 PM   #49
66C10LB
...Fuel filler configuration in inner bedside. Let me know if anyone wants any details about the modifications. Next, weld the new inner bedside panel (with filler), and then frame goes off for sandblasting.
Old 10-19-2023, 03:11 AM   #50
Braunschweiger
You're doing a great job, it'll be another nice truck.
Greetings Harald
My 62 build thread
1966, 283, c10, canada, saddle
