Old 12-21-2017, 03:41 PM   #1
66C10LB
1966 C10 LB 2wd 283 4spd build
Time to start my build thread..
Bought this 1966 C10 LB 283 4sp PS PB Custom model
Pretty much how it was from the factory. Built in Canada
Bought it from the family of the original owner. It has 107000 miles on it.
Here is a picture of when I got it home, and also a picture of it cab-off before work on it.
66C10LB is offline   Reply With Quote
Old 12-22-2017, 12:36 AM   #2
Captainfab
60-66 Nut
Re: 1966 C10 LB 2wd 283 4spd build
That looks like a clean and straight truck
What are your plans for it?
Old 12-22-2017, 01:38 AM   #3
66C10LB
Thanks CaptainFab
Ya, it's decent, but requires the usual rust repair...floor pan, front and rear outer cab supports, pillar btms front and back, inner rockers, outer rockers, some other small pieces to be fabricated. I am working on the passenger side first.
I have two trains of thought about what I would like to end up with...1)completely stock including the colours saddle/fawn/white etc. or 2) mostly stock but choose red in and out and upgrade to fuel in rear, dual master, collapsible steering column.
Thoughts?
Old 12-22-2017, 01:55 PM   #4
Bomp
Bomp's Avatar
Jumped right in, I like that.
Following along
Bomp is offline   Reply With Quote
Old 12-23-2017, 02:07 AM   #5
Captainfab
60-66 Nut
Just build your truck the way you want it to be so you can enjoy it to the fullest.
Thoughts?
Old 12-25-2017, 04:08 AM   #6
66C10LB
Some details (bit out of sequence). Here is the steering wheel repair, kind of close to finished. It's interesting that my 1966 Canadian built truck came with this style of steering wheel. Maybe this is not the original, or maybe it is the original and is this style because this 1966 truck was made in Canada late in 1965?
Old 01-04-2018, 08:20 PM   #7
Lobotie
Lobotie's Avatar
Looking good so far
Following
Lobotie is offline   Reply With Quote
Old 07-12-2018, 01:02 PM   #8
66C10LB
For the bottom of the front pillar post repair, I decided to tack a small, 1/4 inch wide strip of 16g to the inside so that I would have some backing and be able to turn the heat up on the weld to ensure strength...
Last edited by 66C10LB; 07-12-2018 at 01:06 PM. Reason: Wrong picture was uploaded
Old 07-12-2018, 01:22 PM   #9
66C10LB
Finally, passenger side pretty much done. A number of adjustments were needed to the outer rocker and the cab corner to make them work.
Old 07-17-2018, 01:00 PM   #10
jimmythompson1964
jimmythompson1964's Avatar
Looks like you been there and done that before....good work!
jimmythompson1964 is offline   Reply With Quote
Old 07-21-2018, 10:51 PM   #11
66C10LB
Thanks Jimmy! I'm actually quite a newby that this sort of thing, but enjoying the journey. It has been a bit slow, but getting there.
Old 07-23-2018, 08:47 AM   #12
jimmythompson1964
I did not see any bracing, did you test fit your door before you final welded your rocker in place? With all of the metal cut out it can move on so you may want to test fit it now make sure everything is still in line. If this is your fist project you are doing great, and you found the right place to read and learn from, the guys on this site have been there and done that. People on this forum are very knowledgeable and will help you through the learning process. Looks like you are having fun and getting it done.
Old 07-30-2018, 10:38 PM   #13
66C10LB
Thanks Jimmy. Yes I am new to this but enjoying. I did test fit the door and the front fender to the outer rocker several times in the process so I think it is very close. There were adjustments needed (slits in the outer rocker to fit over the pillar bottoms. For the drivers side I am cross bracing in order to speed up the process and add a level of comfort (less worry about things moving).
Old 07-31-2018, 05:43 PM   #14
68Gold/white
I like the idea of a stock build on this pickup.
A good friend of mine had a cool 66, he sold it and I didn't know it at the time. man I regret that...........
His was originally the same color as yours.
Carry On!!!
68Gold/white is offline   Reply With Quote
Old 08-01-2018, 02:50 PM   #15
okndn
Looking good
okndn is offline   Reply With Quote
Old 08-24-2020, 03:35 PM   #16
66C10LB
Getting close to finishing the second side of the cab! Of course alterations had to be made to the pieces that I ordered. Here are the alterations to the rocker and the rear brace. Anyone else finding similar alterations had to be made?
Old 08-24-2020, 04:48 PM   #17
66C10LB
Managed to make a replacement for the bottom flange at the bottom of the back of the cab.
Old 08-24-2020, 10:29 PM   #18
Captainfab
60-66 Nut
All aftermarket body patch panels and most body parts must be reworked to fit correctly.
Nice work on the lower rear cab panel
Old 08-24-2020, 11:04 PM   #19
66C10LB
Indeed, Captain Fab, pretty much every panel.
Took a while to decide how to achieve those curved flanges on the lower centre rear of the cab.
Old 08-25-2020, 11:10 AM   #20
jrusher
Nice work! What did you use to bend and shape those pieces ?
jrusher is offline   Reply With Quote
Old 08-25-2020, 11:17 AM   #21
The Rocknrod
Moderator
The Rocknrod's Avatar
Wow, nice work on that cab bottom piece.
Old 08-25-2020, 12:24 PM   #22
66C10LB
Jrusher, I used a bead roller with a combination of flanging dies, tipping dies, and back to back flat dies for smoothing. It was a fairly low cost bead roller but did the job.
Old 08-25-2020, 12:25 PM   #23
66C10LB
Thanks!
Old 08-28-2020, 10:04 AM   #24
SCOTI
SCOTI's Avatar
x2. Very nice!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-28-2020, 10:07 AM   #25
88Stanger
88Stanger's Avatar
nice work so far!!
88Stanger is offline   Reply With Quote
1966, 283, c10, canada, saddle
