Old 12-12-2023, 09:01 PM   #1
howzzzit
howzzzit's Avatar
Coolant overflow bottle ideas
Anyone mount a small coolant recovery set up on the front of the radiator support? Pictures and ideas please. Thanks
howzzzit is offline   Reply With Quote
Old 12-13-2023, 01:09 AM   #2
HO455
HO455's Avatar
Re: Coolant overflow bottle ideas
Here are some.
http://67-72chevytrucks.com/vboard/s...d.php?t=773213
RIP Bob Parks.
Old 12-13-2023, 02:32 AM   #3
howzzzit
howzzzit's Avatar
What do you think about this? Think I would find a better mount than the hose clamps.
Old 12-13-2023, 09:40 AM   #4
Keith Seymore
Keith Seymore's Avatar
For my '63 Grand Prix I just used the existing windshield washer bottle.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-13-2023, 01:09 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Dorman 603-001
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-13-2023, 03:19 PM   #6
HalfBrit
This one (DeWitts) is similar to the one in howzzzit’s post. Welded the brackets to the existing reservoir tabs, then bolted to the radiator support.
HalfBrit is offline   Reply With Quote
Old 12-13-2023, 03:43 PM   #7
howzzzit
howzzzit's Avatar
Wow that looks great! Too fancy for my truck. I am thinking of mounting the Amazon tank next to the a/c receiver on the front sheet metal. I can bring the hose through the hole where the parking light wires come through on a 72.
Old 12-13-2023, 05:22 PM   #8
LS short box
I got a stainless tank from Speedway Motors. I choose the type that reciculates the coolant back into the radiator.
Old 12-13-2023, 06:10 PM   #9
67C10Step
67C10Step's Avatar
I am thinking about moving this to the driver's side behind the core support now that I have installed a new radiator. The old radiator in this photo sprung one too many leaks. My wife says it looks like a diamond in a goat's ass.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 12-13-2023, 08:29 PM   #10
howzzzit
howzzzit's Avatar
Thought about that. How will you route the tubing?
Old 12-14-2023, 04:03 PM   #11
MARKDTN
I had one of these in a '66 Mustang. I used a large "P" style cushioned clamp to mount it. It worked fine.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-14-2023, 04:23 PM   #12
howzzzit
howzzzit's Avatar
Where might I find such a clamp?
Old 12-14-2023, 09:24 PM   #13
Getter-Done
Getter-Done's Avatar
Amazon has those.
Here's a link below.
You just have to get the one for the diameter of your tank.
Link:https://www.amazon.com/s?k=cushion+c...sl_6zn8qvi7z_p
The early bird gets the worm,
85 Chevy K-20
Old 12-15-2023, 01:49 AM   #14
howzzzit
howzzzit's Avatar
Thanks Getter
Old 12-15-2023, 03:07 PM   #15
72SB
I put the Dorman in my 72. Bought it on Amazon. Use one existing hole and drilled another. used a 1/2" spacer for the offset in core support between holes
72SB is offline   Reply With Quote
Old 12-16-2023, 09:31 AM   #16
1970cstblazer
1970cstblazer's Avatar
Question Re: Coolant overflow bottle ideas
Do you have a pic of the front of your truck with the hood shut? I am curious if that tank is easily seen through the grille.
Old 12-16-2023, 09:41 AM   #17
Sheepdip
Sheepdip's Avatar
This is basically the style I use, mine is mounted on the drivers side between the grill and radiator support.......works for me!
Sheepdip is offline   Reply With Quote
Old 12-16-2023, 01:38 PM   #18
howzzzit
howzzzit's Avatar
If you want to make the tank black you could use Rit dye. I've dyed many white plastic items black using Rit liquid not the powder. Use the whole bottle and as little hot water as necessary. Let er soak and rinse. Wear gloves.
Old 12-16-2023, 01:40 PM   #19
howzzzit
howzzzit's Avatar
Sheepdip how did you route your tubing? I have an a/c condenser in the way or I would mount it on the passenger side. By the way I'm in Modesto. Can I send you a private message on another topic?
Old 12-16-2023, 07:23 PM   #20
CKfan
Nice, clean setup.
CKfan is offline   Reply With Quote
Old 12-16-2023, 10:49 PM   #21
Sheepdip
Sheepdip's Avatar
Sure can on the private message. My tubing comes back across the top of the radiator as I too have A/C stuff in the way. I'll get a pic tomorrow and post it.
Old 12-17-2023, 01:27 AM   #22
howzzzit
howzzzit's Avatar
PMd you. Do you think if I ran the tubing down under the shroud and across to the radiator cap it would be too low to suck the juice back?
Old 12-17-2023, 11:53 AM   #23
old51sedan
old51sedan's Avatar
I bought the same Dorman tank, but for some reason it would not fit behind my grille without a big hassle, so I mounted it on the firewall.
old51sedan is offline   Reply With Quote
Old 12-17-2023, 02:19 PM   #24
howzzzit
howzzzit's Avatar
You 6 cylinder guys have sooo much room. I like the idea, but my firewall is full of factory a/c boxes.
Old 12-17-2023, 05:44 PM   #25
Sheepdip
Sheepdip's Avatar
My hose runs on top between the radiator support panel and the radiator. As long there are no leaks and the overflow bottle has coolant in it, it will suck it back.
