chevy truck fan
Hi, I have 1986 C10 swb. I am trying to find the dims. to locate the pass. side upper shock bolt hole location (in frame)? I need to check/redrill the shock hole location from a frame repair. I am not sure if there is a factory assy. manual for it (similar to the 67-72 trucks)? any info. would be appreciated
![]() thanks! ![]() |
![]() ![]() Join Date: May 2015
Re: Pass. Upper shock bolt hole
I looked at a bunch of frame drawings, none show shock location
Could you not measure drivers side and mirror it to pass side?
![]() Join Date: Mar 2003
Should be a dimple in the frame, I'd find the center of it and drill and watch out for the brake line behind it
#4 | |
chevy truck fan
#5 | |
chevy truck fan
Link to build thread?
Here it is KW
http://67-72chevytrucks.com/vboard/s...=794677&page=5 I thought you were referring to the front.. If the shock is installed on drivers side, measure the installed shock length from bolt center to bolt center.. Then measure how far from top or bottom of frame rail to frameside stud.. Transfer this measurement to pass frame rail in the general area of your patch Then measure the pass side from axle end shock mount to the frame repair area using the installed shock measurement You should be able to visualize where the hole needs to be where all these lines intersect.. It wont matter if your measurement is off a little
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-01-2024 at 01:27 PM. |
Going by this pic,...pic1
I'm gonna say probably in this area...pic2
chevy truck fan
mongo, thanks for the link info & THANK YOU for the replies. I will try your suggestions this weekend. your 1st picks helps. I believe that I might have drilled to "low" making the shock sit "higher" on the pass side... not sure though. hopefully you didn't laugh too much while looking thru my build. I need to add some things as the truck is emissioned & driving now.
