Old 04-13-2024, 10:41 PM   #101
Luke87gt
Re: Purchased a 1969 C10 Short Bed - Pleasanton, CA
Thank you
And if anyone has a recommendation for a dash pad source, I’d be appreciative. Would like to replace mine.
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 04-14-2024, 01:19 AM   #102
Jessdigs
New Member
Very nice truck. I'm currently restoring my 70 in Concord. Maybe I'll see you around the local shows soon. Good luck with it.
Jessdigs is offline   Reply With Quote
Old 04-14-2024, 03:00 AM   #103
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have one of these, on the recommendation of Grumpy. It has a hard plastic core.
https://www.truckandcarshop.com/truc...2/t60_028.html
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 04-14-2024, 07:26 AM   #104
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Purchased a 1969 C10 Short Bed - Pleasanton, CA
I use the Dashes Direct pad. No drama with installation!
https://dashesdirect.com/product/196...-gmc-dash-pad/
Best price is through Summit.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-22-2024, 02:17 AM   #105
Luke87gt
Order placed, thank you for the recommendation. If you have any recommendations on the install procedure, that would be helpful!
1969 C10 Shortbed
Old 07-22-2024, 02:30 AM   #106
Richard
I have a dashes direct dash in hand that I purchased many years ago before they discontinued the stock style and only offer the urethane. Best of luck to those with the current offerings.
Richard
Old 07-22-2024, 04:57 AM   #107
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I just read through this thread. Nice truck and a great find. I'm subbing to watch and possibly offer advice if needed.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-22-2024, 07:43 AM   #108
1970cstblazer
Arrow Re: Purchased a 1969 C10 Short Bed - Pleasanton, CA
The easiest way to remove and install a dash pad is to have the cluster, radio and glovebox removed to access the nuts. Otherwise it is easy.
Old 07-22-2024, 11:25 AM   #109
67carry-all
RE: gas fumes in the garage. Seems like there may be a few potential sources for this, especially the leak at the carb. However, I'd also suggest replacing that gas cap. My truck that otherwise appeared leak-free had a cracked gas cap gasket and filled the garage with fumes. Replacing with a new cap took care of the issue. Make sure it's a "year-appropriate" cap, meaning it's a vented vs. a non-vented cap. Classic Heartbeat, a forum vendor, supplied a nice locking cap.
67carry-all is offline   Reply With Quote
Old 07-22-2024, 12:47 PM   #110
Luke87gt
Thank you, I did replace the gas cap gasket (but kept original cap) which resulted in a much tighter fit. The original gasket was badly cracked all around the perimeter.
I need to get that old carb pulled off and addressed along replacement of the rubber fuel lines. Those are really old and soft.
1969 C10 Shortbed
Old 07-22-2024, 04:10 PM   #111
Bruce F
Nice truck
The engine could be a 230. I have a 69 Short Step low option (ex US government truck) and thought it was a 250 until the machine shop found out it wasn't at rebuild time.
Bruce
Bruce F is offline   Reply With Quote
Old 07-22-2024, 11:17 PM   #112
Luke87gt
Originally Posted by Bruce F View Post
Nice truck
Bruce
Bruce, you have me second guessing myself now. How would I positively confirm?
1969 C10 Shortbed
Old 07-23-2024, 08:11 AM   #113
Steeveedee
Who Changed This?
Steeveedee's Avatar
Not Bruce, but if it is a 250, it should say L22 on the SPID according to this website-
https://outintheshop.com/options.html
~Steven
Simi Valley, CA
Old 07-23-2024, 04:44 PM   #114
Luke87gt
I don’t have the L22… hmmm I guess it could be a 230
Then again, I don’t have L26 stamp either so who knows
1969 C10 Shortbed
Old 07-23-2024, 07:55 PM   #115
Steeveedee
Who Changed This?
Steeveedee's Avatar
For all I know, the 230 was standard on 1/2T and the 250 was standard on the bigger trucks. That would make sense. But who would order the 230 in a bigger truck? Probably the same guy who ordered a heater delete. I'll put money on someone knowing the answer.
Trivia: the Chevy II/Nova came standard with a 143 Cu In 4 cylinder for many years. It's why one could see "250" on the fender of a Nova, as that was an option. The dealer I worked at right out of high school sold three Novas to the local school district. Absolute strippers. One had the optional "Torque Drive" transmission, which was a Powerglide that had to be shifted manually if one wanted to start out in first. Those Novas were utter dogs. If you care to see some embarrassing Chevrolet history, https://www.curbsideclassic.com/auto...er-powerglide/
~Steven
Simi Valley, CA
Old 07-23-2024, 10:19 PM   #116
68bowtie
68bowtie's Avatar
The original engine in that truck was a 250.
Page 8 of this pdf for a CS vin.
https://www.gm.com/content/dam/compa...olet-Truck.pdf
Old 07-24-2024, 01:04 AM   #117
Luke87gt
I received the dash pad (saddle) and replacement lenses today that I’ve started installing (from SummitRacing)
- 2 grill lights (little rectangular ones)
- 4 side markers
- 2 backup lenses
- 2 tailight lenses
The side markers arrived with a thick foam pad resulting in my stock side marker screws being too short, ugh
I’ll have to get some pics.
1969 C10 Shortbed
Old 07-24-2024, 10:54 AM   #118
Steeveedee
Who Changed This?
Steeveedee's Avatar
Good to know, thanks! Makes me wonder about BruceF's SPID.
~Steven
Simi Valley, CA
Old 07-24-2024, 05:55 PM   #119
Luke87gt
Ok thank you, back to 250 😀
1969 C10 Shortbed
Old 07-25-2024, 07:22 AM   #120
KevinK7
KevinK7's Avatar
Like a few others, I just read this whole thread, that truck looks super clean, nice score.
Regarding the fuel smell/system, worth noting (since I ran into this myself) is to check the sending unit pickup 'sock' (filter). This is typically a nylon mesh and over the years can get brittle and 'disintegrate'.
After having my carb rebuilt, I started having major gas issues (leaking into the intake). What I initially thought was a poor rebuild, turned out to be fragments of the pickup sock preventing the float needle from seating.
Best of luck with the truck, I'll be following along
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 07-30-2024, 12:11 AM   #121
Luke87gt
I got the new reflectors installed, they look pretty good.
I did have to get new slightly longer screws as the ones that came on the truck were too short with the new thick foam gasket.
1969 C10 Shortbed
Old 07-30-2024, 12:16 AM   #122
Luke87gt
And some of you may have seen in the other thread but I did pick up a little 350 this weekend. It may be a while before I get to around to the swap however.
1969 C10 Shortbed
Old 07-30-2024, 12:52 AM   #123
68bowtie
68bowtie's Avatar
That’s super nice!!
Old 08-02-2024, 09:31 AM   #124
Luke87gt
Originally Posted by 71CHEVYSHORTBED402 View Post
Mark a painters stick, center of the bolt holes and measure. The holes are in the frame rail walls, and take 1/2" bolts. The rear hole is generally say 1.4" from the back of the rail, so the forward hole is 5"-7.1" in front of that. If leaf springs, wow, might be 5.3", I can tell you how to modify what's available. I'm only aware of 3 patterns, perhaps there are more, as common brackets have more than one bolt pattern. FWW, the bumper brackets extend approx. 8" behind the frame rails. Technically, I measured everything Also FWW, reproduction brackets aren't very good, and may need to be flattened to sit flush to the bumper.
Do you have leaf springs or coils?
I have coils.
I ordered the Brothers tailgate trunions and will do those before I install the rear bumper..appreciate your help
1969 C10 Shortbed
Old 08-11-2024, 12:37 AM   #125
Luke87gt
Finally got the full set of 275/60/15 BFG Radial T/A tires to go onto the 15x8 truck rallies.
Should have those on soon!
1969 C10 Shortbed
