06-07-2024, 03:16 PM | #1 |
Junior Member
Fix the '66: Build Thread
Hey all,
I acquired my dream truck and am kicking off the build! It is a mostly stock, mostly rust free 1966 K10 with amazing patina! I bought the truck along with a set of axles form a 1979 K30 (Dana 60 and 14FF). The plan is 5.3L, SM465, and NP205. I have the engine, transmission, and transfer case ready to go, I just need to decide on an induction system. I am leaning towards a Holley Truck Avenger just to scratch the itch. I have a CJ7 with an LS that I run the stock EFI on, so I dont want to do the same thing over again with the '66. I started an instagram to document the build as well. The handle is @fixthe66 As soon as I figure out how to add photos, I will post them! |
06-07-2024, 06:15 PM | #2 |
Active Member
Re: Fix the '66: Build Thread
Awesome, subscribed!
06-07-2024, 06:52 PM | #3 |
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
06-08-2024, 09:36 PM | #4 |
06-08-2024, 09:47 PM | #5 |
Junior Member
06-08-2024, 10:16 PM | #6 |
Junior Member
I get this error when I try to upload
“Your submission could not be processed because a security token was missing.” |
06-10-2024, 11:41 AM | #7 |
Junior Member
I think I figured out pictures, the files were too large. I am going to try to post a bunch to catch up!
06-10-2024, 11:42 AM | #8 |
Junior Member
Here is the 305A. I got it running and listed for sale. Since it is not original to the truck, I am going to swap in a better engine for my application.
06-12-2024, 05:45 PM | #9 |
Junior Member
Both studs as well as the spring pin were broken off in the Dana 60. Using various methods, I got them all out!
06-13-2024, 12:03 AM | #10 |
Cool, can't wait to see another 4x4 build on here. Give me some extra motivation for mine.
06-13-2024, 12:52 AM | #11 |
Junior Member
Thanks! I’ll try to keep the content coming as time allows!
06-13-2024, 04:07 PM | #12 |
Junior Member
I pulled off the old steering box and installed the Captain Fab steering box bracket. I tried to copy the geometry from aotte1 but the brackets on my frame made me mount about 1" further back. Hopefully I can deal with that using the drag link adjustment.
06-18-2024, 06:50 PM | #13 |
Junior Member
I bolted in the tons this weekend.
Front Axle (Dana 60): Mostly uneventful and was a direct bolt in. I did find a broken main leaf on the passenger side, so I need to address that. I just snugged down the bolts for now. Rear Axle (Corporate 14 Bolt): Not so much a direct bolt in. The center to center on the spring pads is narrower on the 1979 axle. It went together but you can see that the springs and the u-bolts are leaning inwards. These bolts are also just barely snugged. New spring perches are on order and I will weld them in place in the right spot. |
06-19-2024, 06:00 PM | #14 |
You might want to check out this build thread, page one he starts swapping to newer suspension and eliminates the blocks, can help with ride and parts availability. Good to see you getting work in on the truck, not many 4x4 builds around
http://67-72chevytrucks.com/vboard/s...d.php?t=768827 |
06-19-2024, 06:07 PM | #15 | |
Junior Member
06-20-2024, 01:07 PM | #16 |
Junior Member
I finished my steering shaft last night. I cut the stock shaft and welded a borgeson universal joint in. The pitman arm is loose on the steering box, so I need to figure that out. And the drag link is just there to check length, I have all new steering components on order.
06-22-2024, 03:24 AM | #17 |
Got ya, I was just suggesting it since you had found a broken main leaf and would be revisiting the rear suspension at some point.
06-26-2024, 01:25 PM | #18 |
Junior Member
I went through the un-known mileage 5.3 that will be going in the truck. It was disgusting, so I pressure washed and painted everything. I changed every gasket and seal with the exception of the head gaskets. I put in a new melling oil pump. The timing chain was tight and the internals looked good. I also found this tag on the head that tells me that it MIGHT be rebuilt. Overall I am into this engine ~$200
I got a Holley intake and MSD box for cheap on Ebay and will run a Truck Avenger clone for now. I am insisting on a round air cleaner when I pop the hood, so I wont be running the stock LS EFI. If I struggle with the carb, I will get a Holley Sniper. |
06-27-2024, 05:01 PM | #19 |
Junior Member
I stripped the rotten insulation off of the floor and wire wheeled, scrubbed, and pressure washed all the grime. Then I painted it with two coats of POR15 Grey. I have one small rust hole to repair on the driver side, but everything else is solid! Once I have the new engine/trans bolted in, I will patch the hole for the old T-Case, and throw in some carpet.
06-27-2024, 05:12 PM | #20 |
Looking good man! and yeah that looks like a reman engine tag so if the motor overheated they know not to warranty it. Depending on who did the rebuild that could be a good thing with fresh bearings and rings etc but some horror shops out there still.
06-27-2024, 05:37 PM | #21 |
Junior Member
Well I am going to run it and see what happens! I got the engine for free and spent very little on gaskets, seals, and a new oil pump from Rockauto.
