06-25-2024, 09:42 PM | #1 |
Paint, Body & Metalworker
Axle Under Truck Arm? & 5Lug>6Lug?
I've done some googling, which mostly entails this site as search results. I'm curious, could you mount the axle below the truck arm? Obviously the mount needs swapped to the top side of the tube. Also, can I convert the 12bolt rear to 6 lug by swapping axles and brakes? I have to ID my rear as to whether it's an early or later year housing for width. I'm not against get axles made for the width I need. I just don't see the need to swap to a larger rear end when my current one is posi.
I'm looking at potentially converting my 2wd to 4wd. Wondering if I could run a truck arm setup in the rear vs making a 4 link. Thinking swapping the axle to below would give me a lift or get me to 4x4 height. Also looking at Dana 44s for the front and most are 6 or 8 lug. So hence the, convert the rear 12bolt to 6 lug. Thanks for any insight |
06-25-2024, 10:53 PM | #2 |
Born Psycho
Re: Axle Under Truck Arm? & 5Lug>6Lug?
i'm assuming your truck is a 71 or 72, if so you can use axles from a 71 or 72 4x4 to get 6 lugs, use a GM dana 44 from a 1/2 ton for 6 lug front. just move your rear mounting pads to the top of the housing- make sure your driveline angle is correct before you weld them. swapping to leaf springs in the front is pretty straight forward, you'll need the 4x4 spring brackets, and crossmembers for the engine and transfer case. i just sent the last of my 4x4 stuff to two different board members a month or so back, but i'm sure other members can help you out with everything you need.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-26-2024, 01:28 AM | #3 | |
I did read about using the 4x4 axles if it's a later year rear. I'm not positive what I have. My truck is a bit of a heinz 57. It's titled a 67 but doesn't have the 67's steering setup. Front clip is 71/72, bed is 67. I believe the cab is a 67 but it doesn't have the firewall dent that's shown in the identification thread on here. So if I have a 71/72 rear I can get stock axles and if it's a earlier one, I have to get axles made. I have been eying up Dana 44s from square bodies on marketplace. I'm not ruling it out, using stock style stuff, but this project is something for me to stretch my fabrication muscles. I don't get to do much with the work I have lined up and I've been itching to build stuff. So I'm currently down the rabbit hole of link style front suspensions. Also currently on the table is grafting/cutting/welding etc a front frame clip from a newer truck. There's a 2000 gmc 2500 front clip locally for $200 with everything but steering box. I'm intrigued with the independent front suspension. All rabbit hole stuff right now. Thanks for the reply and that info is added to the equation, lol. |
06-26-2024, 01:38 AM | #4 |
The flip from over to under lift will net around 4"-5". I put a 4-link on the front of my K10. Check out my build thread for details. Maybe some inspiration for you.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-26-2024, 03:51 AM | #5 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
06-27-2024, 07:59 AM | #6 | |
I have a 5x5 12 bolt and that's all I know about it until I jack it up and measure the width. I was under the assumption there are 5 lug rears in 67 and that's why I said I'd potentially by axles as they are more narrow then the 71/72. |
06-27-2024, 08:42 AM | #7 |
Roadtrip!
If it is an original 5 lug axle, it is from a 71 and newer 2wd.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-27-2024, 10:51 AM | #8 |
Good to know. I have assumptions that my truck was pieced together and most likely had it's vin tag swapped to a matching title. Doesn't matter to me as I didn't buy it with originality in mind.
06-28-2024, 01:05 AM | #9 | |
06-28-2024, 01:51 PM | #10 |
Ok, so I have 28" tall tires and my gap between the top of the tire and fender is the same as yours. Subtract the 1.5" to make the tire size the same and your 4x4 sits 1.5" taller then my Heinz 57 2wd lol. So, I'd assume yours have sagged a bit but I wouldn't trust my truck as a good measuring point to start with. Lets say your 4x4 is down 1-1.5" with tired springs and a 4x4 is supposed to sit 2.5-3" taller in the rear. The axle swap on a 2wd would put it round a 1.5-2" lift on a 4x4. Which would be ideal for wanting to run 33s.
