Old 06-28-2024, 08:49 AM   #1
57FleetsideC4
57 truck fuel pedal brake pedal issue
Hi, I am finishing a 57 chevy pickup with a 6.0/4L80E DBW and just got the seat back (Stock Bench) and installed. I have a problem with the brake and gas pedal to high. I am using the stock 2005 GMC pedal I shaped to get it away from the tunnel and the brake pedal is a conversion to use the booster/master on the firewall. Doe any company make maybe a adjustable fuel pedal or anyone run into this? Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 06-29-2024, 11:19 AM   #2
57FleetsideC4
Re: 57 truck fuel pedal brake pedal issue
I think I got it figured out. I was able to shim the fuel pedal and move the brake pedal down. Plus I did not have the seal all the way back so that helped. Steve
Old 07-02-2024, 10:39 PM   #3
bigmoe
bigmoe's Avatar
Awesome. Glad you got it figured out. What pedal care you using?
bigmoe is offline   Reply With Quote
Old 07-03-2024, 09:27 AM   #4
57FleetsideC4
I am using the stock pedal/bracket from a 2005 GMC 2500. I had to bed it some to clear the tunnel but seems good now. I believe the brake pedal came from CPP performance. Steve
Old 07-03-2024, 10:07 AM   #5
Joyridin
I had to cut my pedal down a bit and shorten it to make it fit the way I wanted. The pedal hung down too far and hit the floor. I think I chopped 2" out of the pedal length.
Joyridin is offline   Reply With Quote
Old 07-03-2024, 04:40 PM   #6
LS short box
Not a truck project but on my LS3 swapped 80 Camaro I had to make a bracket to move DBW away from the trans tunnel.
I used the stock firewall mounting holes.
Couple of pics.
Old 07-06-2024, 07:57 AM   #7
57FleetsideC4
Couple of pics.
Thanks for the ideas. I was thinking of shortening it up but was able to shim it so feel comfortable now. Will see how it is on the first longer drives. Steve
