#26 | |
![]() Join Date: Feb 2022
Re: C4 Vette sub frame & running 4 of the same wheel?
This eliminates a lot worry about steering problems, opens up my wheel selection and I can run all 4 the same!
1955.1 GMC 100 RestOMod 1972 T120RV 1967 C200 Trail 90 2014 TRD Quad CAB |
#27 |
Chip,
Before I order any rim I want to make sure I understand what you are saying you ordered for your C4 on four corners rims? 16 X 8 rear with 4.75 backspace? 16 X 7 front with 4.75 backspace? I have decided to go with stock C4 on all four corners considering that both vehicles weigh in at about GMC 3150LB curb / Corvett 3293 curb close enough for horse shoes or dancing And it open up my wheel selection wide open!!!! Have you mounted the rims yet, checked them for fitment?
#28 |
Are you an earlier or later gen C4?
Mine is an first gen 84, which stock has the exact wheel on all 4 corners. If you are looking at the later gen, stock might have been different size front to rear with different offsets. I don't know what year your Vette suspension is from. The only reason I went to 16 x 8 with the 4.25 backspacing as my rollers are 6.5 wide with plenty of space, and the widest others have put under these trucks with these suspensions was noted as 8". I may have gone too wide, but all the wheels are identical to keep the footprint equal. With medical issues happening, the only thing I've done is dry fitted the wheel alone on the rear with the fender hanging on the bed last fall. Talked to my tire guy today to say I'll be down in a couple of months with one wheel and a list of tire sizes to keep height required. I might have to order new narrower wheels if they are too wide.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod ![]() '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 Last edited by fauXGT; 06-29-2024 at 12:02 AM. |
#29 | |
which is what my choice was from the oneset to go with the 84-87 suspensions. I may just go with 16" x 7" on all four corners and run my spare! I want to thank all for getting me back on point when it comes to steering geometries!
#30 |
If when I assemble all body parts and I'm too tight in spots, that's probably what I'll have to back size to....16 x 7.
I shoulda gotten one of those wheel offset and size measuring tool that some have been talking about lately.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod ![]() '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
#31 | |
Did not care for it!
#32 |
Ordered a test wheel from Wheel Smith, should be here any day now!
I went back to stock C4 front calipers and rotors with the hopes of running all 4 wheels the same size. Will Post up an update after I test fit the rim and if that go's well, I'll figure out what tires to run on my 16' X 6" rims
| Bookmarks |
| Thread Tools | |
| Display Modes | |
