Old 06-13-2024, 09:45 PM   #1
JDarby
JDarby's Avatar
C4 Vette sub frame & running 4 of the same wheel?
All of you C4 corvette subframe guys attention:
Is it possible to run the same rims on all 4 corners?
I am being told NO and before I lay down the $ I want to make damn sure that is the case.
1955 GMC-100 1st series and I am using Wheel Smith for my step by step wheel measurements. I increased my front cylinders to C5-6 calipers.
running 17" x 7" wide wheel my front will need 1" spacer with a 5.5" Backspace
running 17" x 7 wide wheel my rear will need 1/2" spacer with a 3.5" Backspace
All you FlatOut suspension guys if you have any wisdom you can share with me please do
I am wanting to run smoothies on all 4 with a spare,
Thanks for your advice,
Jeff
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
