07-13-2024, 10:17 AM | #1 |
Active Member
Wanted 67 nos door handle
Wanted 67 only nos drivers side exterior door handle, the body shop was supposed to modify the door to fit the 68-72 handle, when I tighten the bolts the handle tilts and leaves a gap at the top of the handle, any help would be appreciated, thanks Adam
07-15-2024, 10:25 PM | #2 |
Active Member
Re: Wanted 67 nos door handle
Ttt
07-16-2024, 12:09 PM | #3 |
07-16-2024, 07:38 PM | #4 |
Active Member
Thank you do you know if the part number is correct for a 67 only handle
07-16-2024, 09:55 PM | #5 |
The part number on the box is correct for 67 only. I don't know about the casting number on the back of the handle though.
07-18-2024, 12:08 AM | #6 |
Active Member
Thank you I asked for better pictures but never got any
07-18-2024, 01:10 AM | #7 |
The casting number on my original 67 handle does not match the one on his.i suspect a 68-72 handle he has there.
07-18-2024, 09:01 AM | #8 |
Active Member
Thank you
07-18-2024, 12:33 PM | #9 |
Even though the casting # is different it may be 1967 correct. Ask the seller if the bolts thread straight in or at an angle & you will get a positive ID.
07-19-2024, 07:52 PM | #10 |
Active Member
Thanks Mike the seller is not responding
07-21-2024, 09:34 AM | #11 |
I'm pretty sure Key Parts make a repro 67 only door handle.
See here: https://www.ebay.com/itm/155569362173 I bought a set a while back but have not installed them. When I get to my shop. I'll try to take a picture to confirm they are correct. |
07-21-2024, 12:48 PM | #12 |
Here's a picture of a NOS Passenger side handle with the Key Parts Drivers Side Handle
07-21-2024, 12:49 PM | #13 |
Another View
07-21-2024, 12:49 PM | #14 |
One More
07-21-2024, 12:50 PM | #15 |
My Pictures make it hard to tell, but the screws on both go straight in. Not angled down like 68 and later.
07-21-2024, 03:25 PM | #16 |
Active Member
Thank you for the information I'm sure that will be helpful for others also
