Old 07-28-2024, 10:35 AM   #26
Accelo
Accelo's Avatar
Re: Corvette 350 into C10
The brackets and accessories are indeed worth quite a bit. The Sanderson headers are expensive. The 010 casting number confirms the block is a 350. It could be a two or four bolt main. Out of a 3/4T truck ups the chances it's a four bolt block. If it was rebuilt correctly you will have a keeper. Having machine shop documentation is something that I would have kept but not everyone does.
I tracked down an alleged 327 for a fella a while back. Came in his C10 and was sold with the 327 verbally. I was suspicious when I saw the three letters on the end of the block stamping. The stamping had only two letters till 1970 and GM built the last 327 in 1969. He was close, it was a 307.
Still, one can read people and get a general idea of their integrity.
Cheers
Accelo is offline   Reply With Quote
Old 07-28-2024, 11:26 AM   #27
Steeveedee
Who Changed This?
Steeveedee's Avatar
People lie, for sure.One of my younger sisters bought a '66 Malibu with a "4-bolt main 350". Years later, the radiator popped and it overheated badly. I pulled it apart to rebuild it. Small journal 327.
~Steven
Simi Valley, CA
Old 07-28-2024, 12:55 PM   #28
Luke87gt
Thanks again for all the input guys
I ended up purchasing it this morning and it’s in my possession now. It’s got a new 200+ amp alternator (so I’ll be running an e-fan), Performer intake, Edelbrock 4bbl carb with electric choke, TCI starter, MSD distributor, Sanderson headers (which look to be quite expensive), new wires/plugs, and fresh oil/filter replaced yesterday.
Should be a fun project replacing the i6 250 that’s in the ‘69 c10. It’ll probably be a few months before I get around to it.
I need to purchase a new hoist. If anyone has an engine hoist recommendation, please let me know.
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 07-28-2024, 01:41 PM   #29
geezer#99
geezer#99's Avatar
More red flags.
Did he put new filter and oil in it before you picked it up?
Old 07-28-2024, 02:20 PM   #30
Luke87gt
Originally Posted by geezer#99 View Post
More red flags.
Oil/filter is fresh indeed
He actually came by a second time and dropped off a set of motor mounts that he had.
1969 C10 Shortbed
Old 07-28-2024, 02:24 PM   #31
geezer#99
geezer#99's Avatar
If oil was changed before you picked it up, then he’s covered up the shiny little metal flakes found in the oil and filter.
So did he change it prior to pick up?
Old 07-28-2024, 02:47 PM   #32
Luke87gt
Yes
1969 C10 Shortbed
Old 07-28-2024, 02:58 PM   #33
geezer#99
geezer#99's Avatar
You gotta assume possible cam going flat.
You’ll need to open it up for close inspection.
Old 07-28-2024, 04:54 PM   #34
RustyPile
RustyPile's Avatar
There are red flags plastered all over this engine.. Luke87gt, I wish you the very best with this purchase..
RustyPile is offline   Reply With Quote
Old 07-28-2024, 05:48 PM   #35
Luke87gt
Cheers
That was ultimately what made me go with it. Seller seemed upstanding, we spent 45min together, compared projects, etc.
Time will tell of course
1969 C10 Shortbed
Old 07-28-2024, 05:59 PM   #36
too much stuff
Roadtrip!
too much stuff's Avatar
I think you have a couple of options, tear into it and check it out, or put it in and go for it. If the guy seemed decent, i would take a chance on it. Looks like you got some good parts with it. Should be an easy swap. Good luck with it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-28-2024, 06:05 PM   #37
PbFut
Lots if skepticism on this one. Sometimes you actually get a good deal. If seller had a good running motor and wanted a BB, I can see this motor actually being nothing more or less, a decent used engine. Risky buy but most of the accessories are decent and would easily add up to half the price and reusable. I'd go for it to.
As for hoist and stand, can't beat good old Harbor Freight for home level use. I've owned both for close to 20 years. Used less than 10 times but really glad I bought even though I likely stressed the bank account at the time.
PbFut is offline   Reply With Quote
Old 07-28-2024, 07:14 PM   #38
KQQL IT
At the body shop.
KQQL IT's Avatar
Aren't they all corvette 350's til proven otherwise.
Old 07-28-2024, 08:23 PM   #39
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by Luke87gt View Post
Here is more, can anyone confirm this is 350 and from what vehicle/year?
Pos #9 shows the Dress Code numbers as well as a VIN.
Truck engines did not come with VINs, even new, as it was assumed the truck would have a longer service life than one engine's run.
Cars, however had VIN numbers for security purposes.
Your stamped Dress code reads:
V = Flint, MI, 2nd - [V8] engine line/ 09 = September, 05 = 5th day/ TSY. [?]
You should be able to run down this partial VIN stamped in front of the Dress numbers.
Old 07-28-2024, 08:34 PM   #40
'68OrangeSunshine
Only if they're RED, with a shortened Long Bed, Lowered, have Rubber Bands for tires and found listed on Craigslist.
Apparently GM had a third V8 line in Flint, dedicated to producing ten powerplants for each Corvette sold. As they were sure the original owners would burn them up racing.
Old 07-28-2024, 09:08 PM   #41
Steeveedee
Who Changed This?
Steeveedee's Avatar
~Steven
Simi Valley, CA
Old 07-29-2024, 03:14 AM   #42
lil hoodlum
lil hoodlum's Avatar
My .02 cents...
Motor looks good and it should be a 350. $1,500 isn't chump change but not crazy espensive for a used 350 motor.
I'd run it as is or find a way to run it before installing to check compression and listen for any unusaul noises.
I think you got a decent deal and only time will tell if it was worth it.
Good luck!
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 07-29-2024, 09:31 AM   #43
LockDoc
The Older Generation
LockDoc's Avatar
^^^^^ I agree. This is what I would do.... I have started many an engine sitting on the floor of my shop.
Leon
Old 07-29-2024, 02:30 PM   #44
RichardJ
>>I need to purchase a new hoist. If anyone has an engine hoist recommendation, please let me know.<<
Make sure it is tall enough. For a truck, the boom has to reach over the core support and then down at a angle to the top of the engine. If the chain between the boom and engine is too long, you have to really fight to drag the engine back over the core support.
They'll give you a total lifting height, but that won't help you if the boom is laying on the core support and the end of the boom is still a foot and a half above the engine.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-29-2024, 03:28 PM   #45
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I've let the air out of the front tires in a pinch, to gain more clearance to pull an engine.
~Steven
Simi Valley, CA
Old 07-29-2024, 05:56 PM   #46
72c20customcamper
72c20customcamper's Avatar
Never had a problem with the boom . I tend to like removing the whole clip
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-30-2024, 06:52 PM   #47
BAD1916
I’ve always pulled the front clip as well. Way easier especially if you are working alone. On my sons 70 f250 I had to remove the wheels and set it on jack stands barely off the ground to get the engine in and out.
BAD1916 is offline   Reply With Quote
Old 07-30-2024, 11:11 PM   #48
'68OrangeSunshine
Yeah. Same here. When I swapped 292s back in 2002-05, we pulled the Hood, Hood Springs and Hinges, Cowl, Grille, Radiator bulkhead, Driver's fender and fenderskirt. Left the Passenger Side Fender in place for reference.
Gave us a lot more room to operate.
Old 07-31-2024, 12:49 AM   #49
Luke87gt
Here is a question:
With these Sanderson shorty headers, is there a c10 Hpipe or Xpipe I can order for my ‘69 ?
1969 C10 Shortbed
Old 07-31-2024, 01:14 AM   #50
Accelo
Accelo's Avatar
A friend of mine had a new motor to install in his C10.
Three of us went to work early so we could get off early.
Changed the motor that night and he drove it to work the next day.
We had to fix some wiring issues at the same time.
We replaced some solid copper wire with the correct stranded.
I like it when a plan comes together.
