#26 |
![]() Join Date: Mar 2015
Re: Corvette 350 into C10
The brackets and accessories are indeed worth quite a bit. The Sanderson headers are expensive. The 010 casting number confirms the block is a 350. It could be a two or four bolt main. Out of a 3/4T truck ups the chances it's a four bolt block. If it was rebuilt correctly you will have a keeper. Having machine shop documentation is something that I would have kept but not everyone does.
I tracked down an alleged 327 for a fella a while back. Came in his C10 and was sold with the 327 verbally. I was suspicious when I saw the three letters on the end of the block stamping. The stamping had only two letters till 1970 and GM built the last 327 in 1969. He was close, it was a 307. Still, one can read people and get a general idea of their integrity. Cheers |
#27 |
Who Changed This?
![]() Join Date: Jan 2013
People lie, for sure.One of my younger sisters bought a '66 Malibu with a "4-bolt main 350". Years later, the radiator popped and it overheated badly. I pulled it apart to rebuild it. Small journal 327.
#28 |
Thanks again for all the input guys
I ended up purchasing it this morning and it’s in my possession now. It’s got a new 200+ amp alternator (so I’ll be running an e-fan), Performer intake, Edelbrock 4bbl carb with electric choke, TCI starter, MSD distributor, Sanderson headers (which look to be quite expensive), new wires/plugs, and fresh oil/filter replaced yesterday. Should be a fun project replacing the i6 250 that’s in the ‘69 c10. It’ll probably be a few months before I get around to it. I need to purchase a new hoist. If anyone has an engine hoist recommendation, please let me know.
1969 C10 Shortbed |
#29 |
More red flags.
Did he put new filter and oil in it before you picked it up? |
#30 | |
He actually came by a second time and dropped off a set of motor mounts that he had.
1969 C10 Shortbed Last edited by Luke87gt; Yesterday at 02:34 PM. |
#31 |
If oil was changed before you picked it up, then he’s covered up the shiny little metal flakes found in the oil and filter.
So did he change it prior to pick up? |
#32 |
Yes
1969 C10 Shortbed |
#33 |
You gotta assume possible cam going flat.
You’ll need to open it up for close inspection. |
#34 |
There are red flags plastered all over this engine.. Luke87gt, I wish you the very best with this purchase..
#35 | |
Time will tell of course
1969 C10 Shortbed |
#36 |
Roadtrip!
![]() Join Date: Feb 2003
I think you have a couple of options, tear into it and check it out, or put it in and go for it. If the guy seemed decent, i would take a chance on it. Looks like you got some good parts with it. Should be an easy swap. Good luck with it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#37 |
![]() Join Date: Feb 2022
Lots if skepticism on this one. Sometimes you actually get a good deal. If seller had a good running motor and wanted a BB, I can see this motor actually being nothing more or less, a decent used engine. Risky buy but most of the accessories are decent and would easily add up to half the price and reusable. I'd go for it to.
As for hoist and stand, can't beat good old Harbor Freight for home level use. I've owned both for close to 20 years. Used less than 10 times but really glad I bought even though I likely stressed the bank account at the time. |
#38 |
At the body shop.
Aren't they all corvette 350's til proven otherwise.
" That didnt make it any newer " " Dont antique the equipment " |
#39 | |
![]() Join Date: Feb 2002
Truck engines did not come with VINs, even new, as it was assumed the truck would have a longer service life than one engine's run. Cars, however had VIN numbers for security purposes. Your stamped Dress code reads: V = Flint, MI, 2nd - [V8] engine line/ 09 = September, 05 = 5th day/ TSY. [?] You should be able to run down this partial VIN stamped in front of the Dress numbers.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; Yesterday at 08:28 PM. |
#40 |
Only if they're RED, with a shortened Long Bed, Lowered, have Rubber Bands for tires and found listed on Craigslist.
Apparently GM had a third V8 line in Flint, dedicated to producing ten powerplants for each Corvette sold. As they were sure the original owners would burn them up racing. ![]() ![]()
#41 |
Who Changed This?
#42 |
My .02 cents...
Motor looks good and it should be a 350. $1,500 isn't chump change but not crazy espensive for a used 350 motor. I'd run it as is or find a way to run it before installing to check compression and listen for any unusaul noises. I think you got a decent deal and only time will tell if it was worth it. Good luck!
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
