Old 10-20-2024, 10:07 PM   #101
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Originally Posted by D.B View Post
You are doing a heck of a job on this ride. It is going to look great when you get through with it. Looking forward to seeing it when done.
Thank you. I am looking forward to getting this truck back on the road.
pjmoreland is offline   Reply With Quote
Old 10-20-2024, 10:47 PM   #102
pjmoreland
pjmoreland's Avatar
The lower bearing of the steering column was held in place with bailing wire. The original spring and washer were gone. The bearing was rusted onto the steering shaft, so I had to use a torch to get it loose. I soaked the bearing in vinegar overnight, and it cleaned up pretty nicely. There was a bunch of crud floating on the top of the vinegar. Packed it with grease, and it is fairly smooth.
Old 10-22-2024, 01:41 AM   #103
pjmoreland
pjmoreland's Avatar
Removed the steering gear box and welded up a crack in the frame.
Installed a new filler neck grommet. Also removed the sender from the fuel tank and peered inside. There is a bunch of black sludge in the bottom. I'm planning on taking the tank to the car wash to blast it out. I bought some Heet water remover this evening to use afterward.
Old 10-22-2024, 10:40 PM   #104
pjmoreland
pjmoreland's Avatar
Worked on steering today. Installed a new gearbox. Disassembled the steering column to replace the turn signal switch. The threads on the top end of the upper shaft were stripped, so I replaced the shaft with one out of another column I had. Installed a replacement rag joint and intermediate shaft. It is satisfying to have all of the correct parts in place.
Old 10-23-2024, 04:42 PM   #105
57taskforce
All about them K’s
57taskforce's Avatar
Nice work. I did the signal switch in my K20 several years back, it’s kind of a pain in the butt. It’s got to be satisfying knowing that everything is back to the way it should be, as well as knowing it’s a million times safer.
Tyler
Old 10-23-2024, 04:50 PM   #106
pjmoreland
pjmoreland's Avatar
For sure. There's an extremely invasive brake & light safety inspection that I'll have to pass in order to get this truck back on the road, so I've got to make sure everything functions well.
By the way, I decided not to weld that reinforcement plate onto the outside of the frame rail for now since it already has the factory reinforcement plate on the inside. Plus, someone already welded a second reinforcement plate to the inside of the frame rail right where that crack was located. I will be getting the ORD brace you recommended though once my finances rebound a little.
You should see the list of parts I've already acquired for this truck. It's crazy. I have an equally long list of parts that I still need to acquire, and it keeps growing each time I work on the truck. For example, last night I was doing a little organizing of my parts stockpile, and I realized it would be a good idea to test the horn. It didn't work, of course. A friend of mine has one though, so I'll be picking it up from him today.
Old 10-24-2024, 08:58 AM   #107
pjmoreland
pjmoreland's Avatar
Did a couple of little things. Replaced the clips for the headlight adjusters, and replaced the fuel cap. I plan on reinstalling all of the EEC equipment, so I got a non-vented cap.
Old 10-24-2024, 10:18 PM   #108
pjmoreland
pjmoreland's Avatar
I had a little daylight this evening to work on my truck. The drag link tie rod end boots were torn, so I replaced the tie rod ends. I also Welded up a crack in the frame near the front shackle stop.
Old 10-25-2024, 09:41 PM   #109
pjmoreland
pjmoreland's Avatar
Took the gas tank to the car wash and cleaned out the black sludge that was in the bottom of it. Blew it out with compressed air afterward, and then dumped a couple bottles of Heet in it, sloshed it around, and then dumped it out (recommended by LockDoc). Looks decently clean enough now.
Also reinstalled the shackle stop.
Old 10-26-2024, 01:30 AM   #110
pjmoreland
pjmoreland's Avatar
Replaced the disintegrated fuel sender sock.
Old 10-26-2024, 06:51 AM   #111
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice project. I do love them Stepsides.
Old 10-26-2024, 09:08 AM   #112
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1971 K10 Stepside - Getting a Roller Roadworthy
In addition to the rotten boots, it appeared that the drag link was installed backwards.
Old 10-26-2024, 09:11 AM   #113
pjmoreland
pjmoreland's Avatar
Thanks. Someone was making a yard sale out of it, unfortunately.
Old 10-26-2024, 09:12 AM   #114
pjmoreland
pjmoreland's Avatar
I did a little searching on that subject and couldn't find anything conclusive. I didn't like how close the sleeve and clamps came to the knuckle arm when mounted the other way, so I flipped it around.
Old 10-26-2024, 11:56 AM   #115
1970cstblazer
Red face Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Well, I was incorrect on this issue after doing some research.
Here is the factory paperwork from the NOS GM 361098 drag link kit I used on my 1970 Blazer. When I bought it 3 years ago, the instruction sheet was missing, and I copied what was already there on the Blazer..
Note that it states the the steering rod must be assembled with long end forward.
Board member IronCanine's current 1970 K20:
Looks like I will be correcting that this afternoon...
Old 10-26-2024, 12:00 PM   #116
pjmoreland
pjmoreland's Avatar
Oh, well. I'd end up trashing the new boots if I removed it now.
Old 10-26-2024, 01:57 PM   #117
pjmoreland
pjmoreland's Avatar
I like it better with the short tie rod end forward. I tested it through the full range of steering, and there is more clearance this way between the arm and the adjusting sleeve.
Old 10-26-2024, 10:24 PM   #118
pjmoreland
pjmoreland's Avatar
Reinstalled the fuel tank and replaced the vent line hoses.
Old 10-26-2024, 10:31 PM   #119
pjmoreland
pjmoreland's Avatar
Disassembled the front axle. The driver side locking hub did not want to come apart, so I had to make a puller. A couple of parts will need to be replaced. The differential had some water in it. Fortunately, the gears aren't rusty. I will replace the bearings and seals.
Old 10-26-2024, 10:33 PM   #120
pjmoreland
pjmoreland's Avatar
More photos
Old 10-26-2024, 10:35 PM   #121
pjmoreland
pjmoreland's Avatar
And some more
Old 10-26-2024, 10:36 PM   #122
pjmoreland
pjmoreland's Avatar
Last few photos
Old 10-27-2024, 03:51 PM   #123
CUSTOM/10
CUSTOM/10's Avatar
Hey Patrick,
Nice work 👏...
Looks like your infor a complete front-end rebuild.
Just finished mine. Dana 44 front-ends are no fun to rebuild.
Getting the gears setup is a pita. Contract me via pm if you need some pointers.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-27-2024, 04:00 PM   #124
pjmoreland
pjmoreland's Avatar
Originally Posted by CUSTOM/10 View Post
Hey Patrick,
Nice work 👏...
Gary
Yep! Will do.
Old 10-28-2024, 01:47 AM   #125
pjmoreland
pjmoreland's Avatar
I'm waiting for parts to arrive for the front axle, so I worked on the rear axle today. I disassembled it, gave it a quick cleaning with a wire wheel, and sprayed some paint on it. I will be replacing the perches later, so I left that portion unpainted.
Someone did some crazy shimming on this axle at some point. The pinion and carrier shims were mangled. It appears that they enlarged the bearing IDs so that they'd be a slip fit.
I installed new bearings and started the process of setting up the gears. I had to start from scratch on the shims. I did one pattern, and the pinion was too deep, so I adjusted the pinion shim and did another pattern. It still needs some refinement.
