Old 11-11-2024, 11:11 PM   #1
Extended Power
Extended Power's Avatar
Need way quieter exhaust now...
I built my exhaust using the Flow Master Delta 44’s in 3”.
The mufflers are under the box, not the cab.
I had the original Flow Master 40 Series in 2 1/2” before on the old engine, which had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter.
I thought the Delta 44’s were gonna be quieter, but aughhhhh...no.
I want quieter exhaust...I can add cutouts if needed.
The wife is not too keen on going for drives when it’s this loud.
Any recommendations?
PS: I used v-bands on the muffler inlets and outlets, so it should be easy peasy to change them out.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 11-12-2024, 01:23 AM   #2
3drburb
Re: Need way quieter exhaust now...
I've heard that Dynomax Super Turbo are nice compared to most.
3drburb is offline   Reply With Quote
Old 11-12-2024, 09:45 AM   #3
Rickjz
I am enjoying my Magnaflow 11266 mufflers. They are on a Blazer with the top off. I have 3” exhaust.
Rickjz is offline   Reply With Quote
Old 11-12-2024, 09:56 AM   #4
Rickjz
I thought that I went with 3” exhaust but actually it is 2.5”.
Old 11-12-2024, 10:51 AM   #5
Dashman
Active Member
I purposely designed my own exhaust system to place the mufflers further behind the cab on a long bed K10. I also went with Magnaflow in a 4" x 9" (11225, 2.25"). I was amazed at how quiet it was. That was a great idea on the V-bands. I thought of welding those in at the collectors.
Dashman is offline   Reply With Quote
Old 11-12-2024, 10:53 AM   #6
SCOTI
SCOTI's Avatar
Another vote on the Dynomax Super Turbo mufflers. My dually has 1 3/4" long tube Chevelle headers into 3" head pipes w/a H-crossover to the mufflers. I used reducers to go down to 2.5" tailpipes & they exit @ the corners of the bed/bumper.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-12-2024, 11:56 AM   #7
Sheepdip
Sheepdip's Avatar
Where do the pipes exit now? Any exhaust that exits under the truck will rattle your brains out, not to mention when you leave the pavement you look like a helicopter landing.
Sheepdip is offline   Reply With Quote
Old 11-12-2024, 02:01 PM   #8
geezer#99
geezer#99's Avatar
Back in the seventies there was a guy in The Hat that transplanted a rowdy sb into his 70 Volvo p1800. A true sleeper.
He ran 4 Chrysler Imperial turbos. Mufflers just like the turbo max.
He had room for 4 in a smallish car.
Maybe you do to.
Old 11-12-2024, 03:10 PM   #9
Extended Power
I had the headers made with v-bands as well. (Lemons Headers)
Same place as before...just in front of the rear tires.
-did not want them out the back and passing by the fuel tank.
-did not want down drafts as my back alley is dirt. (I spend enough time cleaning and polishing this thing.)
Old 11-12-2024, 04:44 PM   #10
Willshook
Easiest way to quiet an exhaust is to add a crossover. Makes a huge difference.
Willshook is offline   Reply With Quote
Old 11-12-2024, 05:13 PM   #11
LS short box
My vote is for the Dyno Max turbos. Biggest you can fit length wise.
Old 11-12-2024, 06:01 PM   #12
weq92f
weq92f's Avatar
I added an H pipe off long tube 2 1/2 out back through MagnaFlows under bed. It's only loud from the back...in cab noise is not bad.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-12-2024, 07:06 PM   #13
RichardJ
>> had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter.<<
That setup had longer pipes AFTER the muffler.
Short pipes after the muffler are always louder.
Changing the muffler with the same short pipe and what looks like a megaphone tip will change very little, regardless of the muffler choice. You could consider running the pipes over the axle and out the side behind the tires.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-12-2024, 07:12 PM   #14
I liked my Flowmaster Delta 50 series. They were quiet to mild inside, but let you know on the outside they mean business. The ones on my 70 are real quiet, too quiet, but not sure what Generic brand my friend had put on when he had them done 10 years ago.
Old 11-12-2024, 07:33 PM   #15
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I agree with the Dynomax Super turbos. Have the linked set with an H pipe on my sock 350 truck truck for 10 years and ae using them with the newly rebuit small block 400. . Only get really loud is when u stomp on it.
https://www.dynomax.com/catalogsearc...esult/?q=17747
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-12-2024, 07:50 PM   #16
72SB
SpinTech Sportsman XL have a nice note but are not loud
72SB is offline   Reply With Quote
Old 11-12-2024, 09:29 PM   #17
WorldsCrappiestTruck
Active Member
Posts 34-35 for me here. I REALLY dig the setup I have. Barks when I want it to, soft & quiet behind the wheel.
https://67-72chevytrucks.com/vboard/...=852752&page=2
WorldsCrappiestTruck is offline   Reply With Quote
Old 11-13-2024, 10:04 AM   #18
70STOVEBOLT
70STOVEBOLT's Avatar
I have Thrush super turbos in 2.5" mounted just behind the cab, tail pipes exit in the stock location behind the rear tires. They are fairly quiet until you mash the pedal. Truck has a mild 402 with 1 3/4 Hedders with 3 inch collectors.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-13-2024, 01:46 PM   #19
MARKDTN
Another vote for Dynomax Super Turbos.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-13-2024, 02:27 PM   #20
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've used Flowmaster 40 series on pretty much everything I've ever built. Been using them since they first hit the market and the 40 series was all they made. The difference of running the pipes out the back vs. out the side in front of the tires is a huge difference.
I'm fortunate to have a wife that loves the sound of loud exhaust.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-14-2024, 12:02 AM   #21
Mike C
Mike C's Avatar
Do you need 3” pipes? Testing shows until you cross the 600 hp line or so, not any real gain over 2.5”. That will do a lot to reduce the noise level.
On my Camaro I run the 14” case 2.5” DynoMax Super Turbos, and on my trucks I run the 20” case mufflers they used to call the Hemi Turbo muffler. Once again, 2.5” pipe.
I’m a big fan of both. Bit of trivia, the Super Turbo is the old Sonic Turbo that was developed by David Vizard and was THEM performance muffler pre-Flowmaster.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-15-2024, 12:25 AM   #22
KQQL IT
At the body shop.
KQQL IT's Avatar
If you have the room.
A pair of 70 series keeps my rowdy sbc very quiet
Old 11-15-2024, 04:42 AM   #23
Richard
Have a single 3" 70 series big block muffler on my 94, good sound and mild. Many compliments. Installing 3" pipes on my 72 project. Dual 70 series with an X-pipe. Will be a tight fit on the shortbed with all that. Still have to wait and see how it goes. I am expecting pleasing results. Will see when I get to the exhaust install.
Richard
Richard is online now   Reply With Quote
Old 11-15-2024, 07:27 PM   #24
Ekliptix
Ekliptix's Avatar
Another vote for Dynomax Super Turbo. I had loud Spintec mufflers, and switched to the dynomax. Much better.
https://youtu.be/O39GYbJp5jM?si=J9oG1QW_kYBVGcWY&t=125
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 11-15-2024, 09:54 PM   #25
pappy 2
4th set of mufflers are dynomax super pro (american made). From now on will use nothing else.
1st set was flowmaster 44 then the 50's and 3rd set was something a muffler shop assured me i would like, but no so much. All were 2.5 inch on a small block chevy with headers.
pappy 2 is offline   Reply With Quote
