Old 11-04-2024, 11:53 PM   #151
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Painted the perches
pjmoreland is offline   Reply With Quote
Old 11-04-2024, 11:57 PM   #152
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
Welded new perches onto the rear axle this evening. Decided to set them at the stock angle since my suspension is at stock height.
Very nice welds.
Old 11-05-2024, 12:39 AM   #153
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
Very nice welds.
Some of them look better than others, and naturally I chose the nicest one for the photo.
Old 11-05-2024, 05:56 AM   #154
'68OrangeSunshine
I can't weld at all. Wish I did.
Old 11-05-2024, 09:58 AM   #155
loudchevy
loudchevy's Avatar
Nice work cleaning that rearend up. I'm guessing your least aesthetic weld was 1000x better than the booger welds you have ground off that truck.
Love the consistent progress you're making.
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-05-2024, 10:55 AM   #156
pjmoreland
pjmoreland's Avatar
Thank you. I'm looking forward to having the rear end back in place.
Old 11-06-2024, 12:34 AM   #157
pjmoreland
pjmoreland's Avatar
Installed the front carrier and pinion bearings. Thankfully, my wife is entertained when I "cook" car parts.
Old 11-08-2024, 12:12 AM   #158
pjmoreland
pjmoreland's Avatar
Cleaned up the rear leaf springs and u-bolts with a wire wheel and then painted them. It appears that there is a GMC logo on the u-bolt saddles.
Old 11-08-2024, 12:13 AM   #159
pjmoreland
pjmoreland's Avatar
U-bolts and retainers
Old 11-08-2024, 08:22 AM   #160
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1971 K10 Stepside - Getting a Roller Roadworthy
3824491 dates back to model year 1963 and was used through 1972.
Old 11-08-2024, 10:38 AM   #161
pjmoreland
pjmoreland's Avatar
Interesting. I did a search on the part number, and I saw a thread that says these cast pieces like to break in half. I'll take my chances for now, but I should probably replace them eventually.
Old 11-08-2024, 01:16 PM   #162
1970cstblazer
Wink Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Yes, I have broken one. When tightening them, you must tighten slowly and evenly or they will easily break. My donor Blazer supplied another one for the project. 1967-68 trucks did not use these.
Old 11-09-2024, 12:28 AM   #163
pjmoreland
pjmoreland's Avatar
Reattached the rear axle to the leaf springs.
Old 11-10-2024, 01:48 AM   #164
pjmoreland
pjmoreland's Avatar
Spent some time working on the front axle today. Cleaned some rust out od the inside of the housing. Gave the outside a quick cleaning with a wire wheel and sprayed some paint on it. There was a decent sized dent in the diff cover that I straightened out using the Hydraulic press. That cover is thick.
Old 11-10-2024, 01:49 AM   #165
pjmoreland
pjmoreland's Avatar
More photos
Old 11-10-2024, 01:52 AM   #166
pjmoreland
pjmoreland's Avatar
Also cleaned up and painted the rear brake components with high-temp paint.
Old 11-10-2024, 04:12 AM   #167
'68OrangeSunshine
Dude, you're an Artist. You sculpt Chevy Trucks out of rusty steel.
Old 11-10-2024, 08:06 AM   #168
CUSTOM/10
CUSTOM/10's Avatar
Nice work on rebuilding those differentials Patrick !!!
I just completed doing both of mine and it's a lot, but you made it look quick & easy...
Amazing progress !!! Keep it going.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-10-2024, 10:49 AM   #169
pjmoreland
pjmoreland's Avatar
I have this special tool that transfers the rust from the truck to my face.
Old 11-10-2024, 10:53 AM   #170
pjmoreland
pjmoreland's Avatar
Gary
The way the shims go behind the bearings on this Dana 44 looks like a real pain compared to a 12-bolt. It would be nice if everything is still in spec using the same shims, but I doubt I'll be that lucky.
Old 11-10-2024, 08:31 PM   #171
'68OrangeSunshine
I have a similar relationship with Gear Lube.
Seriously -- wear safety glasses.
Old 11-13-2024, 12:45 AM   #172
pjmoreland
pjmoreland's Avatar
It's chilly outside this evening, so I wasn't very excited to be out there laying on the asphalt, but I went ahead and did it anyway. Got the front differential reassembled. The pinion preload and the carrier backlash are good. The carrier preload is good and tight. The gear pattern could be better, but I can tell that it matches the wear marks on the teeth, so I'm not going to mess with it. It feels smooth when rotated.
Old 11-13-2024, 12:47 AM   #173
pjmoreland
pjmoreland's Avatar
More photos
Old 11-13-2024, 12:48 AM   #174
pjmoreland
pjmoreland's Avatar
Last photo
Old 11-13-2024, 07:22 AM   #175
CUSTOM/10
CUSTOM/10's Avatar
Those shims are a PITA... I honed out a set of bearings & races to a slip fit to mock-up the gear pattern. I was changing the gear ratio so the shims were totally different. It was still a PITA.
Good looking work.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
