#701 |
Re: Yet another GMC build
if nothing else, should look sick!
#702 |
![]() Join Date: Oct 2009
Since I cut a brace out to move the tank, making another brace above the tank. Sway bar and links in now. Look at the back of the notch and you’ll see that I bent some 3/4 emt and welded it in before I closed the notch. I can put wiring from the frame rail through rather than around the notch. Did that on both sides.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#703 |
Loooks good.
Canadian hotrods frames have all the electrical, brake and fuel lines run inside their boxed frames. Good idea I guess, it keeps it clean looking. If there were a problem I guess the frame could be opened up or the problem circuit could be ran on the outside. |
#704 |
Bed is back on. Still need wiring and brake lines, and to build a bed cover to hide the ugly. Realizing now that I’ll likely be adding lots of weight which will likely offset any benefit of being a couple inches lower. The rear view already looks better. I have always hated how the gas tank hangs WAY below the roll pan. And I had a frame rail that drooped and required spacers, and I fixed that. Hopefully the sway bar helps. And the rear frame is definitely stiffer now. We’ll see how it turns out.
#705 |
3/4” square frame, stainless strips, 18 gage sheet metal. Ordered a couple quarts of bed liner so I can match the bed. Should cover the hole and look like it was on purpose.
#706 |
So when you open the gate you have a nice little storage spot for things, if you cover the fuel tank with something protective. Looks good.
#707 |
Spray lined the backside. Still need an alignment. The truck is definitely lower, my fender lip was above the tire. And recall that I raised the lip1.5 inches. If I hadn’t there would be some serious overhang. Waiting on the tintable coating to arrive for the top.
#708 |
Your truck looks really good. Gonna look great with the tonneau cover in black.
#709 |
![]() ![]() Join Date: Oct 2014
Very nice work!!!
#710 |
Black was the bottom. Just sprayed the top orange. Now have to hurry and wait for the Raptorliner to dry.
#711 |
#712 |
Installed.
#713 |
Congrats on getting it back together! You work fast.
#714 |
that looks great. nice fast work.
for some reason I thought you were making a tonneau cover for the bed, lol. |
#715 |
Well done
#716 |
I made a big decision and recently sold the truck. It left for its new home today and I hope the new owner likes it. I'm going to try and finish the C10 roadster project that I started forever ago. I kept going back to the 56 and couldn't stop changing things and losing focus on finishing the other truck. It's been a fun 16 years though.
#717 |
#718 |
oh dang! hopefully at least cashed out ... does that mean the c10 gets some splurge money!?!
#719 | |
Part of the deal was that to give it up, I wanted something that I would find acceptable (fast, fun, looks good), and she didn't mind riding in. She ended up finding a 22 Challenger Scat Pack 392 with only 6000 miles on it. I've been driving the same Ram 4x4 for 15 years, so I get a new driver with Brembo brakes and 485hp. She doesn't have anxiety riding in it because it has airbags and ABS. I still have the C10 project, so I still have three cars to her one Kia Optima. Pretty unfair for her. Her stipulation was that I not change anything. We'll see how long that lasts, or how sneaky I can be! C10 will eventually get some love when I have more time. Online college classes keeping me busy and last week I got electrocuted with 277V and fell off a 6ft ladder at work. (Glad to even still be here) Not even allowed to drive at this point and will spend some time recuperating before I can get in the garage again.
#720 |
"but honey, it's just a basic new exhaust" ... *long tubes and header back*
*tuner* ... "i don't know why it's shifting harder babe, i should get that looked at if it gets worse" that color is amazing! |
#721 |
"see the crack in the old plastic intake? i had to replace it" ... "no, i don't know why they have to charge $8000 and it still makes a whistle"
#722 |
A friend of mine actually pulled this one off to get a Whipple on his AWD Yukon Denali. But his wife, she don't know cars so good. My wife, on the other hand, grew up with a car guy for a dad and is not that easy. I didn't know these things had a line lock, paddle shift, and active suspension from the factory. In track mode it shifts like it has a stage 3 shift kit in it, and the previous owner put bullet mufflers on it, so it sounds pretty darn good. And... we took a weekend trip in it, and I got 23mpg on the highway. It's just darn hard to build an old one to do what some of these newer cars can do.
#723 |
lol. Or, with traction control off, she’s says “why does the car keep spinning the tires all the time?”. You say” Dodge put tiny all season tires on it.” Her: “can’t you put on wider performance tires to stop that?” Me : “yes but the wheels are too narrow for wider tires, I’d have to get new wheels too” Result….
Ok, I’ll stop posting Challenger stuff on a truck board. New owner says he loves the truck and is already making some changes.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
