#626 | |
![]() ![]() Join Date: Apr 2022
Re: 67 Camaro Build
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#627 | ||
Re: 67 Camaro Build
![]() ![]() The left side has caught up to the right. I remembered thinking the arm rests look good without the ashtrays.
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#628 |
Re: 67 Camaro Build
[QUOTE=7dee2;9356314]Thanks, that is a good idea. Since the build thread is so far behind the actual build, I can tell you I ended up just using the OE pivot (from the donor car) with a new adjustable length rod and peddle.
You should post a pic of the differences. I didn't know or have forgotten (that's highly likely ![]() ![]() Here is the differences, the 68 patter is a little more "fuzzy" or blurry, its not as a hard edge pattern. Pics are from SMS fabrics website. 68- ![]() 69- ![]()
#629 |
Re: 67 Camaro Build
Thanks for posting, when you mentioned the difference I Googled it but only came up with the 69 patterns. Which seems to be more common when looking for Hounds Tooth covers/material.
Kilmat sound deadener going on the floor. I don’t know if I mentioned this before but I mainly use a thump test. If it sounds solid no need, if it doesn’t sound solid it gets some. Here’s a Fuel Pump Controller kit from Aeromotive that I decided to try. It should prolong the life of our fuel pump by varying its speed using a tach signal. Note: I ended up not being a fan of this controller, details to come later. ![]()
#630 | |
![]() Join Date: Mar 2022
Re: 67 Camaro Build
EXCELLENT plan ! Ash trays are no longer part of any vehicle interior anyway. I do like the clean appearance too. I'll be eliminating them, if I ever get to do interior...seems years away yet. |
#631 |
Re: 67 Camaro Build
Ha, in hindsight I should’ve just gone with my initial idea. It does look better without them, plus with the rollbar I don’t think anyone will ever sit back there let alone light up.
![]() Yep, I installed new ashtrays in the rear armrests right before putting them away. Prepped the roof for the final install of the weatherstripping channel. Just a few holes on the right side A-pillar got covered up from when Kelly (Perks) had installed the roof channel earlier (test fitting the side glass). A quick clearance with the die grinder, then a dab of paint, and it’ll be good to go.
#632 |
Re: 67 Camaro Build
I'm back on building out the dash. Scuffed and painted the outer heater box in preparation for building out the heater. I stole this idea from the trucks and got me some jute padding for behind the dash (?). I don’t think the Camaros had this, but the trucks did. I really like a solid-feeling car/truck, not a tinny, rough feel, so extra effort here and there makes that happen.
#633 |
Re: 67 Camaro Build
Getting closer, I don’t want to cover up any mounting locations or have it interfere with any of the dash components.
#634 |
Re: 67 Camaro Build
I’ve applied the jute padding to about 2/3rds of the cowl’s underside using 3M 90 adhesive. It’s just too tight to try and apply any directly above the peddle bracket assembly. I’ll take a smaller piece and apply it later above the fuse box and left of the peddle bracket.
#635 |
![]() Join Date: Jan 2017
Re: 67 Camaro Build
This build is looking great! keep the updates coming!
#636 |
Re: 67 Camaro Build
Very cool!
"I feel the need for speed!"... as soon as I am done with my nap. |
#637 |
Re: 67 Camaro Build
I will do, thanks you guys, I appreciate it!
I don’t care for these foam gaskets but, they will work with some trimming. The new wiper transmission fits well and I'm preparing for the wiper motor install.
#638 |
Re: 67 Camaro Build
The wiper motor is installed, but the supplied wiper motor Phillips head screws were junk (good tight fit but the screw heads are trying to strip out) I’ll replace them later with better hardware. I tested the motor earlier when I first received it but I wanted to test the motor and trans in the car. AOK, it looks like it’s going to work out fine, no issues other than the mounting hardware. Good instructions, but beware it wires up completely different than the factory WW motor and switch (ground vs positive switching).
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 01-01-2025 at 01:35 PM. |
#639 |
Re: 67 Camaro Build
Good to know info if I ever need to replace my original piece. Funny how the aftermarket stuff hooks up 180 of stock. I had a actuator valve for my headlight doors like that. Had to swap vacuum hoses on the ports for it to work right, lol. The next valve was then back to stock, go figure. I love my hideaway headlights but I have to swap that valve every couple years as the rubber diaphragm goes bad.
#640 |
Re: 67 Camaro Build
This’ll work very well with the big block and tall valve covers, and no brake booster for the fitment win.
![]() I am starting to build out the heater box, the only OE parts are the fan and motor, wish me luck. And yes, I tested that old 66 date stamped blower motor again and it’s a peach! Using the same crappy foam gaskets (Repops kit that was also used on the Y-duct) that’ll work here also. After gluing I used some gorilla tape also to keep it in place.
#641 |
Re: 67 Camaro Build
Nice snug fit for the heater core, so far so good.
#642 |
Re: 67 Camaro Build
Here it is all built out on the work bench. I didn’t trust that everything would fit before wrestling it into the car.
#643 |
Re: 67 Camaro Build
I tried some factory-style speaker grills from Heartbeat City Camaro. They didn’t line up very well with the Kicker speakers. I opted for these less expensive imported ones from eBay. They line up better and hide the hardware.
#644 |
Re: 67 Camaro Build
Thanks for the picture of the 3M strip calk. I was wondering what to order for my '55 belair and you helped me!!!!
Take Care Troy |
#645 |
Re: 67 Camaro Build
I've had a few boxes of 3M strip caulk over the years and the last one I bought last year is NOT what it used to be. The strips are smaller in diameter, thickness, and they didn't bother to cut them thru. I try to pull 1 strip and get half the row coming with and it turns into a messy fight to separate them. I'll look for something different next time.
#646 | ||
Re: 67 Camaro Build
Took a ride out to my friend Rex’s place to check out some black 66 Corvettes. One is an LS swap he’s been building to flip. I really like the black with red interior on this one. The other is a very correct local car I’ve known about for many years. The original owner passed, and it has changed hands a couple of times since. Rex is finishing a beautification that started years ago by getting it running and driving for the current owner.
#647 |
Re: 67 Camaro Build
Ran a tap to make threads for the new door switches and pulled the mismatched A-pillar gutter screws. Replaced with flush mount screws in preparation for the channel and weatherstripping. The goal is a good seal and no wind noise. That’s a big goal on these old cars but it's worth a try.
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 01-15-2025 at 02:45 PM. |
#648 |
Re: 67 Camaro Build
The weatherstrip channel is going in with some extra attention to the A-pillar corners. I think this is an area that can leak and possibly create wind noise. So, a little body mastic in the corner, foam gasket, and channel, then some more right in the corner before the weatherstripping to make a good seal.
#649 |
Re: 67 Camaro Build
The end of the pillar cover to pillar structure should have a good squirt of seam sealer in that corner. Mine was buried in sealer and under the roof rail channel where you put the mastic, which will seal that, but the open end of the cover could allow rain to get under it.
#650 |
Re: 67 Camaro Build
I've noticed the factory was quite liberal with sealer everywhere they used it on original cars. In our case, more sealer in this particular area certainly wouldn’t have hurt. Our parts car didn’t have much sealer on the A-pillars either. Who knows, with earlier repaints, it may have just been removed by the time it finally got to us.
The left side is ready and I’m finding I don’t care much for the push-pin type of attachment.
