Old 11-30-2024, 10:52 AM   #626
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: 67 Camaro Build
Originally Posted by Lost in the 60's View Post
Being mine is a '67 with deluxe, I wasn't aware the '68 deluxe doesn't have the arm rest. Mine does have the fold down seat too, so I would have the arm rest either way. Must be why I never paid attention to the difference. That or my "short attention span" that my Mom heard at parent conferences for years...
I've always felt the '68 deluxe interior was the classiest of the 3 years. I like the '67 with the stripes, but the '68 looks more plush and refined. I'm the odd man out on the '69 hounds tooth, as I really don't like that pattern.
The 68 houdstooth is prettier than 69 as the "tooth" pattern is smaller than 69's. My uncle had a 68 with factory deluxe houndstooth and headrests. Quite the fancy interior. Yeah I am glad my 68 is a factory deluxe car, the capper on the interior was then having the N34 option (wood wheel). I do have a complete fold down rear seat I picked up years ago for my 68, but Ive yet to install it since 80% of my interior is still original and in great shape.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 12-01-2024, 09:45 AM   #627
7dee2
7dee2's Avatar
Re: 67 Camaro Build
What are planning to use for a throttle pedal ? I bought a Lokar Midnight series pedal, to get away from the solid rod and have a more adjustable cable. The issue with that was, it placed all the force of pedal movement on that firewall location and it will flex and crack in a short time. The original pedal used the 2 floor pivots to absorb a lot more of that force than I realized. I had to make a plate to reinforce the mount area on the firewall.
At this point, you could use the mounting bolts to hold a painted reinforcement in place without welding, maybe even on the inside to hide it.
Thanks, that is a good idea. Since the build thread is so far behind the actual build, I can tell you I ended up just using the OE pivot (from the donor car) with a new adjustable length rod and peddle.
You should post a pic of the differences. I didn't know or have forgotten (that's highly likely ) the pattern differences.
The left side has caught up to the right. I remembered thinking the arm rests look good without the ashtrays.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-01-2024, 02:54 PM   #628
CAMAROBOY68SS
Re: 67 Camaro Build
[QUOTE=7dee2;9356314]Thanks, that is a good idea. Since the build thread is so far behind the actual build, I can tell you I ended up just using the OE pivot (from the donor car) with a new adjustable length rod and peddle.
Here is the differences, the 68 patter is a little more "fuzzy" or blurry, its not as a hard edge pattern. Pics are from SMS fabrics website.
68-
69-
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 12-04-2024, 10:44 AM   #629
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks for posting, when you mentioned the difference I Googled it but only came up with the 69 patterns. Which seems to be more common when looking for Hounds Tooth covers/material.
Kilmat sound deadener going on the floor. I don’t know if I mentioned this before but I mainly use a thump test. If it sounds solid no need, if it doesn’t sound solid it gets some.
Here’s a Fuel Pump Controller kit from Aeromotive that I decided to try. It should prolong the life of our fuel pump by varying its speed using a tach signal.
Note: I ended up not being a fan of this controller, details to come later.
Brett
Old 12-07-2024, 10:47 AM   #630
Lost in the 60's
Lost in the 60's's Avatar
Re: 67 Camaro Build
EXCELLENT plan ! Ash trays are no longer part of any vehicle interior anyway. I do like the clean appearance too. I'll be eliminating them, if I ever get to do interior...seems years away yet.
Lost in the 60's is offline   Reply With Quote
Old 12-08-2024, 09:27 AM   #631
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Ha, in hindsight I should’ve just gone with my initial idea. It does look better without them, plus with the rollbar I don’t think anyone will ever sit back there let alone light up.
Yep, I installed new ashtrays in the rear armrests right before putting them away. Prepped the roof for the final install of the weatherstripping channel. Just a few holes on the right side A-pillar got covered up from when Kelly (Perks) had installed the roof channel earlier (test fitting the side glass). A quick clearance with the die grinder, then a dab of paint, and it’ll be good to go.
Brett
Old 12-11-2024, 11:47 AM   #632
7dee2
7dee2's Avatar
Re: 67 Camaro Build
I'm back on building out the dash. Scuffed and painted the outer heater box in preparation for building out the heater. I stole this idea from the trucks and got me some jute padding for behind the dash (?). I don’t think the Camaros had this, but the trucks did. I really like a solid-feeling car/truck, not a tinny, rough feel, so extra effort here and there makes that happen.
Brett
Old 12-15-2024, 09:18 AM   #633
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Getting closer, I don’t want to cover up any mounting locations or have it interfere with any of the dash components.
Brett
Old 12-18-2024, 10:20 AM   #634
7dee2
7dee2's Avatar
Re: 67 Camaro Build
I’ve applied the jute padding to about 2/3rds of the cowl’s underside using 3M 90 adhesive. It’s just too tight to try and apply any directly above the peddle bracket assembly. I’ll take a smaller piece and apply it later above the fuse box and left of the peddle bracket.
Brett
Old 12-18-2024, 12:57 PM   #635
69cam
Re: 67 Camaro Build
This build is looking great! keep the updates coming!
69cam is offline   Reply With Quote
Old 12-18-2024, 02:03 PM   #636
NONHOG
NONHOG's Avatar
Re: 67 Camaro Build
Very cool!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 12-22-2024, 09:42 AM   #637
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Originally Posted by NONHOG View Post
Very cool!
I will do, thanks you guys, I appreciate it!
I don’t care for these foam gaskets but, they will work with some trimming. The new wiper transmission fits well and I'm preparing for the wiper motor install.
Brett
Old 12-26-2024, 10:03 AM   #638
7dee2
7dee2's Avatar
Re: 67 Camaro Build
The wiper motor is installed, but the supplied wiper motor Phillips head screws were junk (good tight fit but the screw heads are trying to strip out) I’ll replace them later with better hardware. I tested the motor earlier when I first received it but I wanted to test the motor and trans in the car. AOK, it looks like it’s going to work out fine, no issues other than the mounting hardware. Good instructions, but beware it wires up completely different than the factory WW motor and switch (ground vs positive switching).
Brett
Old 12-26-2024, 10:54 PM   #639
CAMAROBOY68SS
Re: 67 Camaro Build
Good to know info if I ever need to replace my original piece. Funny how the aftermarket stuff hooks up 180 of stock. I had a actuator valve for my headlight doors like that. Had to swap vacuum hoses on the ports for it to work right, lol. The next valve was then back to stock, go figure. I love my hideaway headlights but I have to swap that valve every couple years as the rubber diaphragm goes bad.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 12-29-2024, 09:15 AM   #640
7dee2
7dee2's Avatar
Re: 67 Camaro Build
This’ll work very well with the big block and tall valve covers, and no brake booster for the fitment win. I like the RS option (it looks so cool!), but early on, I decided not to hassle with it for this build—you know, with that whole Grumpy Toy III look we're going for.
I am starting to build out the heater box, the only OE parts are the fan and motor, wish me luck. And yes, I tested that old 66 date stamped blower motor again and it’s a peach! Using the same crappy foam gaskets (Repops kit that was also used on the Y-duct) that’ll work here also. After gluing I used some gorilla tape also to keep it in place.
Brett
Old 01-01-2025, 01:33 PM   #641
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Nice snug fit for the heater core, so far so good.
Brett
Old 01-05-2025, 09:10 AM   #642
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Here it is all built out on the work bench. I didn’t trust that everything would fit before wrestling it into the car.
Brett
Old Yesterday, 10:27 AM   #643
7dee2
7dee2's Avatar
Re: 67 Camaro Build
I tried some factory-style speaker grills from Heartbeat City Camaro. They didn’t line up very well with the Kicker speakers. I opted for these less expensive imported ones from eBay. They line up better and hide the hardware.
Brett
Old Yesterday, 01:08 PM   #644
Troy Sr
Troy Sr's Avatar
Re: 67 Camaro Build
Thanks for the picture of the 3M strip calk. I was wondering what to order for my '55 belair and you helped me!!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old Today, 11:51 AM   #645
Lost in the 60's
Re: 67 Camaro Build
I've had a few boxes of 3M strip caulk over the years and the last one I bought last year is NOT what it used to be. The strips are smaller in diameter, thickness, and they didn't bother to cut them thru. I try to pull 1 strip and get half the row coming with and it turns into a messy fight to separate them. I'll look for something different next time.
