Old 01-11-2025, 12:09 AM   #26
Sheepdip
Sheepdip's Avatar
Re: Blower Motor Circuit Question
Originally Posted by JoePolo View Post
Ahh mine worked with the harness unplugged so I assume that diode is good. Figured it would pop even unplugged.
I would say the diode is good as it jumps between + to - mine was definitely bad.
Sheepdip is offline   Reply With Quote
Old 01-11-2025, 12:25 AM   #27
Rust_never_sleeps
Rust_never_sleeps's Avatar
May not be necessary, but most multimeters do have a diode test function
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is online now   Reply With Quote
Old 01-11-2025, 02:53 AM   #28
RustyPile
RustyPile's Avatar
A diode is simply an electrical check valve.. It will pass current in one direction and block it in the other. A "diode tester" DVM is not necessary.. Set the resistor testing mode to 1K ohm- 10K ohm.. Like most electronic components, a diode cannot be tested while it's in the circuit, so disconnect one lead. Connect the meter leads to the diode leads. Make note of the reading, then reverse the leads and take another reading.. One reading should be high resistance, and the other reading should be low resistance.. If the diode is shorted, it will test low resistance on both readings.. If it's open or partially open, it will read high resistance on both readings.
RustyPile is offline   Reply With Quote
Old 01-11-2025, 04:17 PM   #29
Rust_never_sleeps
I've had that feature on every MM I've owned since the 80's, so I just use it instead. :shrug:
