Old 01-07-2025, 01:27 AM   #1
JoePolo
Blower Motor Circuit Question
Reviving a 72 C10 that’s been dead since the 90s. It’s a factory AC truck.
Blower motor fuse/AC fuse (25A) is popping whenever the switch is turned on from the off position. I had a switch that worked from our Blazer so I pulled the connector and hooked it up out of the panel and blew the fuse again.
With the switch in the off position I have power to the input and I accidentally jumped it with the test light to the terminal just above and it actually kicked the blower motor on. So I know the motor isn’t stuck.
Resistor? God I hope not, I know they are deep in the box.
Relay? On the side of the box. I might have one of those I could test too.
My seat is out right now so trying to get anything that might be under dash figured out now.
Thanks guy.
JoePolo is offline   Reply With Quote
Old 01-07-2025, 03:56 AM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Blower Motor Circuit Question
First guess when the circuit blows immediately is that there's a short to ground, particularly since your motor isn't bound up.
Should be able to confirm with a multimeter(continuity to ground from the fuse terminal with that switch on)
Relay is at least closing the circuit, so could be OK
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-07-2025, 04:07 AM   #3
JoePolo
Thanks I’ll run that test. I am assuming I need to use the fuse terminal that always is powered even after the fuse pops? Sorry I’m pretty handy but electrical isn’t my strong suit.
It pretty close to instant pop, motor definitely doesn’t click on. I actually left the test light on the terminal at the switch while clicking the switch on and the test light dims.
Old 01-07-2025, 04:57 AM   #4
Rust_never_sleeps
1. For continuity, you'd want the other terminal, since that runs to the motor
2. Ground short is usually instant, might be indicating a different problem, could be just due to inherent delay.
Old 01-07-2025, 05:20 PM   #5
JoePolo
Got it, I'll test it tonight. I can also resistance test the switch itself I would assume.
The reason I have this switch to test with is, our Blazer was doing a weird thing, and still is (I never solved that problem either). Where the blower motor on high will basically intermittently cycle to slower speeds (low and medium seem to work as they should) and sometimes be stuck as slower speeds for the most of the time when in high. Changed everything but the resistor. I always put off getting to the damn resistor. Why GM buried it so far in the box is beyond me.
Old 01-08-2025, 09:32 PM   #6
RustyPile
RustyPile's Avatar
When tracking down shorts and other issues that would blow a fuse, I use to tool in this link. It's very easy to use, connects to the fuse box terminals of the blown fuse.
https://www.jbtools.com/sg-tool-aid-...ntpage-nosto-1
RustyPile is offline   Reply With Quote
Old 01-09-2025, 12:09 AM   #7
JoePolo
Got a minute to do the test. Definitely the circuit has a short. It instantly reads 0 ohms. I unplugged the blower motor with the same result.
Guess now I need to start tracing out wires after I buy that tool.
Old 01-09-2025, 12:34 AM   #8
Richard
Disconnect the relay and try the switch. IMO you should replace the 50+ year old resistor and the relay regardless, They will fail if not already. A few screws on the s-duct and two to remove the s-duct adapter on heater core box. Resistor is right there. With the seat out it is easier.
Richard
Old 01-09-2025, 11:25 AM   #9
Sheepdip
Sheepdip's Avatar
Another scenario...Unplug the A/C compressor and try it. I had this problem, and it turned out to be that little jumper wire that grounds the clutch coil was bad/grounded out. That will pop your fuse instantly
Sheepdip is offline   Reply With Quote
Old 01-09-2025, 12:07 PM   #10
JoePolo
Which wire is that? Mine has a small little wire with what looks like a resistor in it right at the connector. I will be trying that next running it with the AC compressor unplugged. Thanks.
Old 01-09-2025, 12:15 PM   #11
RustyPile
RustyPile's Avatar
That's not a resistor, it's a diode. Its purpose is to "cushion" the voltage spikes generated when the clutch coil's magnetic field collapses.
Old 01-09-2025, 02:30 PM   #12
JoePolo
Ahh thanks, so any idea where the jumper wire “Sheepdip” had the issue with is?? Thanks
Old 01-09-2025, 04:29 PM   #13
Rust_never_sleeps
Compressor clutch is literally between the compressor and the pulley. That clutch magnet is "excited" electronically. Two wires in, and one grounds out on the passenger side of the housing IIRC.
Might look like the attached wiring diagram
Old 01-10-2025, 12:21 AM   #14
Rick Bollinger
There is a dark green wire going to the compressor with a 2 wire plug in where it plugs into the compressor right behind the pulley. A black wire coming out of the plug and going to ground on the side of the compressor. If that diode is bad it could allow current to flow to ground and short out. So to check that you would have to check with a meter or disconnect both the green and ground from the compressor and turn on to see if you still blow a fuse.
Rick Bollinger is offline   Reply With Quote
Old 01-10-2025, 12:54 AM   #15
JoePolo
So pretty sure I have the same issue as stated above. I resistance tested the green wire at the compressor switch, with the compressor connected, direct to ground. I disconnected the plug at the compressor, tested the green wire and no short. Hooked it up to the compressor and direct to ground. So I reinstalled the old compressor switch, disconnected the compressor plug and was able to run the blower motor to my hearts content.
So think I need to get myself a compressor clutch. Luckily the AC hasn’t worked since the 90s like the rest of the truck so I won’t miss it until I get a chance to replace it.
Old 01-10-2025, 04:56 AM   #16
Richard
Maybe look a the switch that engages the compressor as well. It would only be actuated when A/C is on. If it is providing a path to the compressor at all times it is stuck closed.
Richard
Old 01-10-2025, 12:08 PM   #17
JoePolo
I already checked that switch both on and off the car. Resistance tested on the bench as well as operated on the car as well. It’s working find. The problem is 100% the AC clutch at this point.
Old 01-10-2025, 06:01 PM   #18
Rust_never_sleeps
That's a pretty ugly failure scenario, I would never have thought of it grounding there, thanks for that, Sheepdip
I have this bookmarked off the Summit page (for when I get to rebuilding mine)
Pretty good pic of what they look like if your clutch hasn't gone kinetic
Old 01-10-2025, 06:04 PM   #19
JoePolo
Agreed I would have gotten there eventually just by unplugging things and trying fuses haha but was great to have the heads up.
Old 01-10-2025, 08:07 PM   #20
Rust_never_sleeps
Just FTR, that page(p74 in my copy) from the HEATER AND AIR CONDITIONING section of the manual seems complete.....
BUT the full truck wiring diagram(594 for my type) in the Electrical and Body section only shows one wire to the fan and no relays.
I'll typically go to that full diagram first, so I added a note there for next time
Old 01-10-2025, 09:27 PM   #21
Sheepdip
Sheepdip's Avatar
When I had this fuse blowing problem it took me and a buddy a couple of hours thru process of elimination and an Ohm Meter to finally find it. Mine was the little jumper wire or diode was bad; I proved it by clipping/cutting it. I just replaced the whole plug-in pigtail, which by the way if I remember correctly, they make one with, and one without the diode..glad to pass the info along.
Old 01-10-2025, 09:28 PM   #22
JoePolo
Ahh mine worked with the harness unplugged so I assume that diode is good. Figured it would pop even unplugged.
Old 01-10-2025, 10:25 PM   #23
Rick Bollinger
You can ohm the compressor clutch. It will show some resistance but not none. I just checked my old compressor that worked when I pulled it off. It read 4.1 OHM's My new sandan read 2.9 and it has never been ran. I don't know the lowest number but if it's reading 0 then it's toast.
Old 01-10-2025, 10:44 PM   #24
JoePolo
Yup it’s reading 0 I did that last night.
Old 01-10-2025, 11:24 PM   #25
PbFut
Clutch replacement is not difficult but you need a decent set of clip ring pliers and puller. These parts are quickly disappearing from the catalogs. I would not put off a purchase thinking better times will come.
PbFut is offline   Reply With Quote
