Old 01-19-2025, 07:10 PM   #301
IronCanine
IronCanine's Avatar
Re: 1970 K20 Z62 Full Restoration
Eric got the doors hung and the glass in and started loading them up. As stated the plating is a problem when restoring hardware. Striker plates still needed a little love when they got back from getting re-phosphated.
The silver door plug has been a problem for a bit. The reproduction ones pop out and poop out pretty quick. Now silver isn't available anymore (that I know of). These come black and have to be painted. But they seem pretty decent quality.
Got the born on date decal on. Thanks as always to Jeff (member ChipFlyer) who does such a great job with these and the SPIDs.
Speaking of...member Roger Koop restored our vent windows and did a great job too. We did swap out the glass for date coded versions.
IronCanine is offline   Reply With Quote
Old 01-19-2025, 07:20 PM   #302
IronCanine
IronCanine's Avatar
The blue interior pieces didn't match each other from the factory...but it really is hard to get new pieces that talk to each other now.
The vinyl reproduction panels are ok...not awesome. As they were when we did the Blazer 10 years ago, the wood grain doesn't match OE. I still had some 3M Di Noc that I'd put on those panels. It seemed 10 years old. I didn't love how it laid down. I think I'm going to order fresh and replace that.
The panels themselves are a pretty good factory color match. But reproduction pulls and escutcheons are not even close. I color matched those bits.
The texture, trim and "puffiness" of the panel is also off as you can see in the pic.
Panels are just on for the moment..will come off for mirror brackets and trim installation.
...Also, it is crazy how light affects your perception of these colors. The pics on the ping pong table are closer to what you see in real life...not baby blue.
Old 01-19-2025, 07:25 PM   #303
IronCanine
IronCanine's Avatar
Eric also got the booster and MC on. Hard to believe that this huge assembly did not have a brace. Also got the throttle linkage, ground straps and several vac lines on.
Something that I didn't realize until we got to work on this...but these trucks had a jumper line/extension of the lead that went to the brake distribution block. The harness line is still shorter than needed, but we'll have to make up this extra lead too.
Old 01-19-2025, 07:39 PM   #304
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It all looks great. I swear ol blue has a brace on the booster. I'll look when I go to my shop Tuesday.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-19-2025, 08:02 PM   #305
IronCanine
IronCanine's Avatar
Thanks! 71 and 72s definitely had braces. I'm not aware of any 70 3/4Ts that had em from the factory.
Old 01-19-2025, 11:36 PM   #306
72chevylover1
Junior Member
Wow! Checking this thread and finding a new post is always exhilarating!
72chevylover1 is offline   Reply With Quote
Old 01-20-2025, 09:17 AM   #307
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1970 K20 Z62 Full Restoration
None of the '70's I've seen had any additional booster braces from the factory. I definitely know my grandfather's 1970 K20 never had them. I added both to my 1970 Blazer when I added the 1972 disc brake setup.
1970cstblazer is online now   Reply With Quote
Old 01-21-2025, 08:54 PM   #308
72chevylover1
Junior Member
Another question Sir, what color code is this truck? Does it have metallic? Almost looks like it in the pictures. Thanks
Old 01-21-2025, 09:59 PM   #309
IronCanine
IronCanine's Avatar
The color code is 538, which is the conventional two tone code for dark blue 508 and white 521.
508 was the code for dark blue for several years...but it wasn't always the same dark blue. 1969 508 is different from 1970 508 and 1971 508. This dark blue as previously stated was a 1970 only color.
It is most definitely metallic. This is the main reason that the exterior paint is base/clear. It gives us the luxury of being able to buff the paint and address any issues pretty easily without affecting the metallics.
Because we wanted to recreate the Fremont firewall marks, we painted that (along with a few other strategic spots) with single stage.
Old 01-21-2025, 10:16 PM   #310
72chevylover1
Junior Member
Ok that makes total sense. Some areas looked glossier than other areas and that makes sense why. Absolutely love your color, this might be taboo to say here but I want to paint my 72 K20 either the dark blue poly or medium blue poly with the white 521 on the cab and between trim molding. I know it's only 70 specific but man that metallic is stunning! Love your truck! Also how did you find a cab top with marker light mounts? The before pictures it didn't have them, or maybe I'm blind here. Just found a full set of NOS marker lights on ebay
Old 01-21-2025, 10:21 PM   #311
1970cstblazer
Since the Blazer is almost completed, My next project will be a clone of this which looks just like my grandpa's K20 except his had 10.00-16.5 tires.
Old 01-21-2025, 10:40 PM   #312
IronCanine
IronCanine's Avatar
I like a lot of the factory colors, but this is probably my favorite and one of the big reasons I bought the truck. There aren't a lot out there, so the more the merrier.
With regard to the roof skin...you are correct, this truck did not come from the factory with cab lights. I wanted to add them. I had sourced a donor skin off of a parts truck. But I got lucky and Pete (DeadHeadNM) found and alerted me to an NOS cab light skin on eBay. It's one of only two I've ever seen. I of course jumped on that immediately. It's one of the 2 or 3 biggest scores on the project to me.
Old 01-21-2025, 10:51 PM   #313
72chevylover1
Junior Member
Yeah those cab lights look super
Old 01-26-2025, 05:02 PM   #314
IronCanine
IronCanine's Avatar
A fun week with very exciting updates.
Even though it's not quite ready to go on, I went ahead and dressed out the GB door. I posted about this in a thread dedicated to GB emblems since I'd not seen it highlighted elsewhere and thought it might be useful to someone. To affix the emblem, tubular nuts are required (3/16" hole, 1/8" stud) which are readily available on the internet. I got these off Amazon. Most of you probably know this, but I was surprised at the lack of coverage on it. Nuts push in...emblem pushes in. Pretty easy.
I got the SPID on. Again, thank you to Jeff (ChipFlyer) who did a great job. I did make two changes and four additions. Tach and 4sp were changes and caps, cab lights, NoSpin, and tilt were additions. I wanted hooks on there, but I can find no factory examples of 1970 trucks with a chrome front bumper and hooks. So I put the hooks on and left them off the SPID. By the book you couldn't have them. So I consider it a "dealer add" item. I'll eventually do the same with a set of buckets. You couldn't get A50 and Z62 together on a pickup. This truck will start out with a bench to show it in it's most correct factory form...but sometime down the road I've got two buckets that will make their way in.
My truck is a late 70 so it could have a tilt from the factory. I did find two 1970 tilt SPIDs...and luckily one from Fremont so I feel good about the SPID wording on that one.
And as we do, I kept the truck's original unrestored GB door with its factory SPID as a record of how it really came.
Finally, I reproduced the 4WD decal because the one available for purchase is lacking. Larry (member DavisChevy) had a perfect original from a 70 that was not on the GB. Of all the decals we've reproduced this is the best IMO. Because we got everything including the sheen (it's a little matte) spot on.
Old 01-26-2025, 05:19 PM   #315
IronCanine
IronCanine's Avatar
A few hiccups as we moved on to trim. I picked up NOS taillight bezels because the reproductions are so far away from OE (see comparisons between OE and repro in hand and NOS on the truck). And it was only appropriate since we'd sourced all the NOS lenses.
You have to on the 69-70 back up lenses if you want to have the bullseyes.
But I did not seek out NOS lower molding because I really wanted it to be bright and fresh and all pieces matching. And we'd had success with repro belt trim in the past. Adding to the challenge is that if we did go with NOS there seems to be less black trim available than woodgrain. And piecing a set together means risking blacks that don't match and having to refinish, yada yada yada.
But I almost broke down and starting trying to piecemeal it when Eric first began fitting the lower molding. The profile and finish was great, but the subtle fits at the short bends on the ends didn't seem awesome.
I spoke with Mel and Larry and both made me feel better. Mel advised that reproduction pieces can be variable now. And Larry said he even had to work his NOS set. In the end it was moot. Before I could start trying to buy what I could find, Eric had massaged what we had into a lovely result.
Old 01-26-2025, 05:31 PM   #316
IronCanine
IronCanine's Avatar
We set the core support Thursday night. If we said it once, we said it ten times over the last couple of days, how nice it was to have an NOS core support this time. If you saw how we handled the core support on the 69, you'll feel that. Eric got the fenders prepped and we got them hung on Friday. And he finished up the molding (among other things). Probably just random and luck...but NOS core support and NOS fenders translated to zero fender shims and the gaps were great.
It really looks like a whole truck now. Of course I can't wait to see the grille and hood on there. Even though there are still some fires to put out and I'm sure new problems will present themselves, this is a really fun stage of the build.
Old 01-26-2025, 05:54 PM   #317
1970cstblazer
Thumbs up Re: 1970 K20 Z62 Full Restoration
110% on the front hooks with the chrome bumper on a 1970. My Blazer has dealer installed aftermarket hooks on it because of this. They are far more beefy than the GM hooks, so it never bothered me that they were there.
Some 1970 Customs had a glove box emblem that did not have the black lettering. Don't know why there is a variation with that.
The bullseye reverse lenses are now reproduced. I opted for NOS lenses on my Blazer even at 10 times the cost.
Old 01-26-2025, 07:19 PM   #318
IronCanine
IronCanine's Avatar
Cool. I did not know that.
Old 01-26-2025, 08:14 PM   #319
1970cstblazer
https://www.ebay.com/itm/11606015880..._redirect=true
Old 01-26-2025, 09:57 PM   #320
68bowtie
68bowtie's Avatar
That paint color is on point
Old 01-27-2025, 12:09 PM   #321
rodstored-72
chevy truck fan
rodstored-72's Avatar
truck is looking fantastic!! very nice job/work!!
rodstored-72 is offline   Reply With Quote
Old 01-27-2025, 01:30 PM   #322
Orange71shorty
Looking absolutely beautiful
Orange71shorty is offline   Reply With Quote
Old 01-27-2025, 04:49 PM   #323
IronCanine
IronCanine's Avatar
It has turned out better than I imagined.
You guys are very kind. Thanks. Appreciate the nice words.
Old 01-27-2025, 06:23 PM   #324
72chevylover1
Junior Member
It doesn't get any better than this! That color is awesome!!
Old 01-28-2025, 02:54 PM   #325
Ol Blue K20
I'm loving it!! So beautiful.
Dale
1970, 4x4, factory, k20, restoration
