Old 03-29-2025, 12:10 AM   #5276
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: What did you do to your truck today.The 3rd chapter
3757-- Did you make your wooden Dash and Glovebox Door [and Ash Tray cover] yourself?
Nice.
Old 03-29-2025, 10:56 PM   #5277
zicc1835
zicc1835's Avatar
Originally Posted by 3757chevy View Post
Nice I like that 70's GT wheel . I have one that was in my '67 Stepside when I sold it. I got it back when I bought the frame and other parts from the guy I sold it to. He only used the cab and hood for a Tahoe frame with LS . My '67 horn cap fits it.
ill say nice dash.... and I do have a stock horn cap for GMC I will try thanks for that tip
zicc1835 is offline   Reply With Quote
Old 03-30-2025, 01:08 AM   #5278
3757chevy
3757chevy's Avatar
Nice.
No. It was in the truck when I bought it in 1997 but I got it back with the buy back . Not sure if I'll use it this time around. Saving it in a box for now.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 03-30-2025, 05:50 PM   #5279
'68OrangeSunshine
Pretty artifacts nonetheless.
Old 03-30-2025, 07:26 PM   #5280
3757chevy
3757chevy's Avatar
They are cool. Took some work to make them. I sanded and refinished them a couple times while I had the truck and I had added after market gauges and tach.
MIKE
Old 03-30-2025, 10:19 PM   #5281
68isgreat
I've been busy the last week or so. After painting the frame on my 68 K10, I installed the gas tank, installed new shocks, dropped in my new crate 350 tbi/K case 700r4/241c combo, and installed a new 4 row aluminum radiator. I ended up using a trans crossmember from a 1990 Suburban, which fit great, except for having to drill new holes in the frame. The height using the stock 87-95 rubber trans mount is perfect, giving me a 4 degree engine angle (I might shim it up to 3 degrees), and clearance for the front driveshaft is wonderful. The double cardan front driveshaft, also from a wrecking yard 1990 burb, fits perfectly, extended halfway down the slip yoke after installation. The rear is at the driveline shop being shortened. Rear pinion angle is 7 degrees, so I'll have to shim it up to 3-4 degrees once I get a full gas tank and bed on it.
Here are a few pics:
68isgreat is offline   Reply With Quote
Old 03-31-2025, 11:17 AM   #5282
loudchevy
loudchevy's Avatar
Drove the C10 on the Street for the first time and took some pics of a mostly complete truck in the driveway
First time around the block
First trip on a major street to get some gas
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-01-2025, 08:06 PM   #5283
Orefactory4x4 swb
I can’t wait to fire mine up here soon and take it for a ride
Orefactory4x4 swb is offline   Reply With Quote
Old 04-01-2025, 08:18 PM   #5284
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by zicc1835 View Post
made the switch today horn works !! plenty comfy now!! these OEM Camaro or maybe Vega wheels are a direct fit this one was on my 72 Cheyenne ...".Basket case build" when I bought it and I switched to a wood wheel
As long as it's not sticky which they tend to do....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-04-2025, 10:03 PM   #5285
zicc1835
zicc1835's Avatar
not sticky and I put a color on it today not sure how its gonna look I had a darker color on it but my better half said it was too drab ....I do like it when she takes interest so I used the light color reinstall it tomorrow
Old 04-05-2025, 02:39 AM   #5286
'68OrangeSunshine
not sticky ....
The 67/68 [and earlier] steering wheels got sticky in high humidity because of their composition. They were a ''Composition'' of ground Walnut shells and glue. [The same Composition they used for first generation skateboard wheels.]
For some reason, in high humidity water vapor was absorbed into the wheel, and some of the glue wept out. I learned from frends in San Diego, if you rubbed the wheel with surf board wax, the stickyness was countered.
With the newer style two-arm wheel in Model Year 1969, the steering wheels were cast in Cycolac, a tough plastic that bowling balls are also made of. '69 / '72 wheels should not get sticky.
Old 04-05-2025, 11:14 AM   #5287
zicc1835
zicc1835's Avatar
done looks better than black?
Old 04-05-2025, 01:56 PM   #5288
awryexperiment
Ground and pounded the upper track bar bolt out of its bracket. Someone had welded the bolt and nut to the bracket for some insane reason.
I would have left it alone except for the constant clunking from the non-existing track bar bushings.
The lower bolt (axle) is tighter than heck so I anticipate bursting a vein trying to get it loose. The grinder may be employed for that one as well.
awryexperiment is offline   Reply With Quote
Old 04-05-2025, 01:57 PM   #5289
awryexperiment
duplicate
Old 04-05-2025, 11:34 PM   #5290
3757chevy
3757chevy's Avatar
Man, that looks great!
MIKE
Old 04-06-2025, 12:13 AM   #5291
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Scrubbed it off and went to a car show. Left the driver's door window down and someone threw a flyer about a future car show in. #litter
Member #Richard and I had a good time chatting and looking at the old iron. Had burgers at the Rock and Roll Cafe, too. I saw several examples of vehicles I had and never should have sold.
~Steven
Simi Valley, CA
Old 04-06-2025, 02:13 AM   #5292
lil hoodlum
lil hoodlum's Avatar
Sounds like you had a great day!
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 04-06-2025, 08:22 PM   #5293
zicc1835
zicc1835's Avatar
thank you......
Old 04-06-2025, 08:30 PM   #5294
Steeveedee
Steeveedee's Avatar
Indeed!
~Steven
Simi Valley, CA
Old 04-12-2025, 03:01 PM   #5295
sixty8HDC30
Taking the fan off my 68 327 in order to more easily adjust my valves and I accidentally smacked the water pump pulley into the pristine original style radiator. Slammed the hood and walked away FML.
sixty8HDC30 is offline   Reply With Quote
Old 04-12-2025, 04:18 PM   #5296
Ol Blue K20
I like it!
Dale
Old 04-12-2025, 07:29 PM   #5297
'68OrangeSunshine
Not quite as bad, but a couple years ago, I was changing out the Heater Core on my '68 C/10 w/292 L6 for an NOS Core.
I thought, I'd done a pretty good job of it. After I finished rebolting the fender screws on the Fender Skirt, I noticed the phillips drywall screws I had shot to mount it had pierced the metal core and coolant was dripping down.
Old 04-12-2025, 08:15 PM   #5298
zicc1835
zicc1835's Avatar
I like it!
me too ...thank you .....I wasn't sure but I like it too
Old 04-13-2025, 09:40 PM   #5299
zicc1835
zicc1835's Avatar
took the radio out today it wasn't working ....tossed it pleasantly surprised PO didn't hack up the dash ...looking for recommendations on a retro blue tooth capable ....maybe ill get the kick panel speakers ??
Old 04-15-2025, 06:46 AM   #5300
un4gvn!
un4gvn!'s Avatar
I got the 540 installed and running.
un4gvn! is offline   Reply With Quote
