Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 04-23-2024, 11:31 PM   #76
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 Suburban 4X4 3/4 Ton K20 "The Beast"
Originally Posted by nsiti View Post
Some fine tuning of the placement of the gas tank.
It looks like that is going to line up really well. I had some problems with that on my Panel Truck.
Leon
Old 07-05-2024, 11:12 AM   #77
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Coming together and looking good!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-14-2024, 12:48 PM   #78
HO455
HO455's Avatar
It looks like things are moving along nicely.
As to the fuel vapor reducer you might be able to mount it where the factory mounted their fuel vent trap. They're behind the rear panel on the drivers side.
First photo is the factory 71-72 piece and the arrow in the second photo points to one installed. The last one from the factory manual.
A thread on the factory system.
http://67-72chevytrucks.com/vboard/s...d.php?t=687417
RIP Bob Parks.
Old 12-04-2024, 04:17 PM   #79
nsiti
Active Member
We're back at work on the Suburban and my mechanic promised me he would "kick it into high gear." Famous last words, but excited to be making some progress.
We removed the old suspension, which was a real bear given all the fused metal. Here are a few photos of our progress installing the new Offroad Design suspension with 5" lift. The truck looks awfully high to me, hopefully it settles down a bit!
nsiti is offline   Reply With Quote
Old 12-04-2024, 04:39 PM   #80
nsiti
Active Member
Following-up, we are hard at work assembling a small block 350 engine (stroked to 427) which I custom designed with the help of the good folks at Competition Products and their neighbors at Howards Cams.
I was pretty adamant about using all American manufactured parts (Dart, Callies, Howards, Clevite, AFR, etc.) which I believe I was 99% successful at. Here are some photos. She looks beautiful to my eyes.
Cheers, and hopefully more to come
-Nick
Old 12-05-2024, 11:17 AM   #81
LockDoc
LockDoc's Avatar
-Nick
Looks pretty nice to me! Nothing like new parts.....
Leon
Old 01-22-2025, 06:24 PM   #82
nsiti
Active Member
Well, we're back at it again, like a herd of turtles!
Installed the steering box brace purchased from Offroad Design. The final result looks very good and sturdy. I will add, though, that the fit was quite a bit off from what I would have expected. Proper fitment required a fairly long cylindrical extension (not supplied). In addition the brace didn't fit flush to the frame, necessitating some customization on our side. Neither is mentioned in ORD's online instructions, the former is mentioned in the instructions that came with the brace, but the latter is not. Improper advertising if you ask me. And then folks wonder why restorations take so long.
Old 01-22-2025, 06:58 PM   #83
nsiti
Active Member
We also tackled the task of permanent installation of the of the Aero Tanks 40 gallon gasoline tank, which was another task that required much thought. We were again surprised at the amount of customization that we had to do to get a proper placement and fit in our Suburban. So much so that we wonder how Aero Tanks can claim that it is a custom fit for Blazer's and Suburban's. Unless of course we missed something. In the end, you will see we decided that we had to lower the tank, which necessitated some modifications to the frame, in order to properly allow for fuel to flow down the line into the tank, as well as for the tank to fit below the wooden floor board with enough space for the top fuel injection lines. Not shown in the photos below will be the last step of reinforcing the frame for the cut-outs we made. Lastly, we're adding an access panel in the wooden floor board in case we need to get at the fuel pump. Any comments or suggestions to our approach are welcome.
Cheers,
Nick
Old 01-22-2025, 07:12 PM   #84
nsiti
Active Member
Third and final post for today, which will bring us up to date. We encountered a snafu with the engine build (and a couple of missing accessories that were an oversight, haha).
After installing the Howards custom ground camshaft and testing for clearance, there was rod interference at one of the cylinders, presumably due to the longer 4" stroke. Upon inspection of my purchase invoice, which called for a small base circle cam, and in discussions with Howards, it seems they sent me the wrong camshaft. To their credit they agreed to regrind a cam upon confirmation of their error. The cam is now in their facility and I'm waiting to hear back from them on the best course forward.
I hope everyone is having a good start to the new year and look forward to your comments. I'll follow-up with more progress as time and effort permit!
-Nick
Old 01-22-2025, 07:23 PM   #85
LockDoc
LockDoc's Avatar
Welcome to the one step forward - two steps back crowd. It really slows a guy down for sure. Good luck with the cam replacement. I hope they make it right with you.....
Leon
Old 01-24-2025, 03:04 PM   #86
Killer Bee
Killer Bee's Avatar
Happy Friday Nick! I have been quietly following along. very nice work and thank you for taking the time to post your progress.
I have similar goals for a pair of these that I'll be getting started on in the very near future retirement.
I too will be keeping small blocks for factory fitting convenience and go with strokers for better low end torque.
keep up the good work and please keep us posted
my rusty heaps https://67-72chevytrucks.com/vboard/...&postcount=332
Old 01-24-2025, 03:55 PM   #87
nsiti
Active Member
Thanks, I spoke with Competition Products today and they confirmed that there was an error on their end, so Howards is regrinding me a new cam on a small base circle. Of course, that could mean a two month wait, but the most important is that it fits and works well!
Hi and thanks for your comments. Good luck on your future builds. I like the stances of your Suburbans!
Old 05-22-2025, 02:45 PM   #88
nsiti
Active Member
I thought I'd report back with the little progress that's been made over the past few months.
The camshaft came back from Howards and was re-installed. This time it was a perfect fit. They never confirmed what the problem was. I suspect they had sent me the wrong grind initially. This made it so we could continue with the top end of the motor, see attached photos. Any suggestions as to what color to paint the engine block when it's assembled? The truck will be painted Dark Olive Metallic, with a white roof and upper rear barn doors (including rear pillars).
One interesting thing to note about the Dart Sportsman block is the peculiar design of the dipstick hole, which does not allow much clearance. This necessitated some grinding of the freeze plug boss on the block as well as the dipstick tube base so that the Milodon 22005 stainless braided could fit.
In addition, we finally got the rear wood bed seated and placed on new bushings.
Now to finalize the bodywork in preparation for painting this summer.
Cheers,
Nick
Old 05-22-2025, 10:30 PM   #89
LockDoc
LockDoc's Avatar
Cheers,
Nick
That is looking great! It will be good to see it with some color on it....
Leon
Old 05-23-2025, 01:36 AM   #90
Richard
I would suggest that you address the rear suspension before going on the road. The rear shackle flip hanger needs to move forward so the shackle is pointing down. The way it is now it will most likely invert and lock the spring against the frame not allowing any movement. Real bad ride and a recipe for disaster. Have to be careful when going to a compression type shackle. Proper placement is needed to avoid inversion. The spring cannot compress as you have it now. Probably why you think it sits high.
Richard
Old 05-23-2025, 07:57 AM   #91
nsiti
Active Member
Richard, thank you
We are also concerned about the shackle flip angle, so I reached out to Offroad Design, where the kit was purchased from. Kyle over there responded as follows:
Regarding the weight sitting on the springs, there is a body but it more or less is a bare shell at the moment. It makes sense that your shackles are sitting at a forward angle, our springs are much more reactive to weight than a standard lift kit springs and a set of springs for a Suburban are built heavier to start with to compensate for the addition body weight. Once the truck is full assembled the springs will flatten out and correct the shackle angle.
Nevertheless, this remains a concern for us and we agree this needs to be addressed before hitting the road. I really appreciate your comment and wonder what you think of ORD's response? What angle would you consider safe, and do you have suggestions for us to consider in case their theory is not correct?
Regards,
Nick
Old 05-23-2025, 09:44 PM   #92
Richard
Richard, thank you
Regards,
Nick
Would bet if you hit the shackle up with a hammer (dead blow if you have one) with the truck weight on spring it will swing up to the frame. If you hit it down it might swing back. As it sits the spring is bound up and in use the shackle will want to swing the wrong way. The shackle needs to be in path of rear swing at full droop to prevent inversion. Hope that makes sense.
Richard
Old 05-27-2025, 12:40 PM   #93
nsiti
Active Member
Richard, thanks, my interpretation is that we need to make sure the shackle swings towards the rear. We'll definitely address this when more weight is placed on the rear. The springs and shackles will definitely need some persuasion from a dead blow hammer (and hopefully that's all)!
Old 05-28-2025, 02:33 PM   #94
Richard
Unfortunately the hanger needs to be moved or the spring de-arched to make it longer at rest. If just hitting the shackle to move it with a load on it. As soon as unloaded such as going over a bump the spring will pull shackle back as it is now and next bump will invert it to the frame. With a compression shackle as you have the shackle must be in the rear path with the spring unloaded. Make sense? Just trying to help you understand how it will work.
Richard
Old 05-28-2025, 05:24 PM   #95
nsiti
Active Member
Hi, yes, ORD says the spring will de-arch with some movement and some weight on it. I'll report back on the actual outcome!
Old 05-29-2025, 12:45 AM   #96
Richard
I came across this by accident and thought it may help https://67-72chevytrucks.com/vboard/...1&postcount=71 About the max angle you can get away with on a compression shackle. Notice there is zero weight on the spring.
Richard
Old 11-29-2025, 04:31 PM   #97
nsiti
Active Member
Hi all, I hope you had a wonderful Thanksgiving.
I'm back to report that the build continues. It's painfully slow progress but we are very close to the paint stage. Hopefully it's all downhill after that (famous last words!).
In the meantime, I'm still dealing with the rear leaf spring issue where the ride angle is improper and too high (see posts 79 and 83 for photos). I continue to be in conversation with ORD as to how to best proceed. Based on our analysis and thoughtful comments by Richard and others on this board we have pushed back against the theory that the rear springs will settle. Unfortunately, the rear leaf springs were improperly designed.
Originally, I ordered a full suspension set, with 5" lift including rear shackle flip, from ORD and it seems they miscalculated in the design of the rear leaf springs (the front are fine).
When I placed the order I was not asked for the weight of the vehicle, which is stock, except for the 40 gallon fuel tank. Now I am being asked for the weight and thought I would get some advice from you as to how to respond. Any assistance would be appreciated. I've also posted this in the 4x4 section.
Once this is settled, I trust I will have more time to post lots of progress photos in the coming weeks.
Thanks,
Nick
Old 11-29-2025, 05:45 PM   #98
LockDoc
LockDoc's Avatar
It might be hard to figure with a 40 gallon tank. There will be a lot of weight difference full and empty (or almost empty). Approximately 330#. I suppose you would use half of that for a static weight.
Here is the information for the '72 3/4 ton 4x4 Suburban posted by member "Vectorit" back in 2013.
3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b
Here is a link to the full thread for anyone that might need it...
https://67-72chevytrucks.com/vboard/...d.php?t=575238
Leon
Old 12-01-2025, 07:47 PM   #99
nsiti
Active Member
Hi, thanks for sharing.
I've given some thought as to how to account for the weight of a larger gas tank. It's heavier than stock (maybe 50 lbs?), plus 20 gallons additional max capacity (124 lbs), so that's about 175 lbs extra weight when full. That's the equivalent of an average person's weight. These heavy duty springs probably wouldn't sag much with an extra 175 lbs of weight, but something to consider in the design.
I also looked at the full range of vehicle weights in the link you provided and compared them to the figures you posted, which raises some concern as to accuracy for the 1972 3/4 ton 4x4. Notice that the weight difference of the doors (4,141 lbs) vs gate (4,585) figures you posted is 444 lbs, while in all other instances the differences are near zero. Any idea why that might be? I would guess it's a typo.
To cross reference, I looked at the official Chevy Suburban 1972 spec sheet and read that the curb weight is 4,857 for the 8-cylinder K20 variant (with a fairly even 2,374 lb / 2,483 lb front / rear split).
All this analysis made me think, what are we trying to measure when designing for the weight load capacity of rear leaf springs? They are not going to support the entire rear weight of the truck, but rather the frame and body weight, excluding the axle, wheels and tires, right?
Any additional feedback would be appreciated.
Regards,
Nick
Old 12-02-2025, 10:54 AM   #100
LockDoc
LockDoc's Avatar
Regards,
Nick
I didn't read the whole chart but yes, that weight difference is suspicious. Like you suggested it may just be a typo.
I can't offer much else because the '69 Suburban I built didn't need any adjustments and my '67 Panel Truck already had drop springs under it when I bought it.
Leon
