#30 |
![]() Join Date: Dec 1999
Re: 1972 Suburban 4X4 3/4 Ton K20 "The Beast"
Unfortunately the hanger needs to be moved or the spring de-arched to make it longer at rest. If just hitting the shackle to move it with a load on it. As soon as unloaded such as going over a bump the spring will pull shackle back as it is now and next bump will invert it to the frame. With a compression shackle as you have the shackle must be in the rear path with the spring unloaded. Make sense? Just trying to help you understand how it will work.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
| Bookmarks |
