Old 06-09-2025, 01:41 PM   #1
Loco83
Loco83's Avatar
Passed Smog
Was sweating bullets for a while, had to get my 83 smogged this year, went thru the normal routine prior to taking it in, new plugs, cap and rotor,finally switched out the plug wires and coil as they have been on the truck since I don't know when, and oil change and filters, went on the rollers and he did the initial test and it failed, high HC readings, under the hood he went and he made some adjustments and I could hear the RPM 's change, this went on three times and on the final run all the lights were green on the tester, PASS.
HATE GOING THRU THIS CRAP EVERY 2 YEARS.
Loco83 is offline   Reply With Quote
Old 06-09-2025, 02:08 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Passed Smog
I helped one guy I worked with years ago.
He would always come find me at his testing time.
I would pull the PCV valve out and plug it, then drop the timing till it would barely run.
It would pass with flying Colors.
That just made no sense at all.
After it passed I would put it back the way it was.
The early bird gets the worm,
85 Chevy K-20
Old 06-09-2025, 03:06 PM   #3
Loco83
Loco83's Avatar
Re: Passed Smog
Wish it was that easy, BUT NO! not in Cali.
https://www.facebook.com/SmogCheckPr...1459050973088/
Old 06-09-2025, 03:16 PM   #4
Getter-Done
Re: Passed Smog
I can only imagine.
They didn't even raise the hood or put a mirror under the vehicle back then.
85 Chevy K-20
Old 06-09-2025, 06:38 PM   #5
truckin 79
Re: Passed Smog
I put a AEM wideband air fuel gauge in mine because the mechanics here in CO look at a carb like it is a space alien addition. It sometimes get addictive watching the air fuel gauge and what it is doing.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-10-2025, 04:42 PM   #6
kglowacky
Re: Passed Smog
in Texas this year all inspections are no longer needed on trucks/autos of a certain age. Not sure of the age but my 78 did not need inspection. YEA
kglowacky is offline   Reply With Quote
Old 06-10-2025, 11:02 PM   #7
Getter-Done
Re: Passed Smog
It is the same here in my county now.
I am so Glad.
85 Chevy K-20
Old 06-11-2025, 08:57 AM   #8
Rickysnickers
Rickysnickers's Avatar
Re: Passed Smog
ID got rid of all smog inspections about two years ago, as well.
Old 06-11-2025, 01:28 PM   #9
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Passed Smog
Loco, I completely can understand your panick, I too went thru the same angst as I was getting my LS swapped '86 to pass emissions her in PHX AZ. the engine aspect ofcourse passed easily, but the equipment aspect was a hassle. I had to (luckily still had) connect the OG Canister to "atleast" look like it was connected correctly . for me the real hassle was the fuel tanks and vacuum hold. I "learned" a few tricks to get by & was able to get a "pass". out here AZ allows the ability to get a 5yr tag so I luckily have a few years left to drive before having to jump thru the hoops again. I think it is soo silly, the engine runs soo much cleaner than the original 305 Carb motor, but yet the state makes it soo hard to let this happen.
rodstored-72 is offline   Reply With Quote
Old 06-11-2025, 01:43 PM   #10
Loco83
Loco83's Avatar
Re: Passed Smog
Hoping Lenos Law passes to get rid of these smog checks.
https://www.youtube.com/watch?v=sI_Dj7A9-kE
Old 06-11-2025, 06:59 PM   #11
72c20customcamper
72c20customcamper's Avatar
Re: Passed Smog
NY no emissions testing on cars and trucks over 25 years old . And the ones that still get emissions all they do is plug in to the computer if you have no check engine light you pass as long as the computer test ready so you can’t clear a code just prior to testing . My 07 3500 with a Cummins has never been emissions tested . Sometimes NY gets things right.
Even if you put a new LS motor in a vehicle over 25 years old no emissions testing just the safety inspection. And I think it’s $12 bucks for safety and $21 for emissions with safety
But then again you rarely see a 25 or older car being used as an everyday driver .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-12-2025, 09:27 AM   #12
SCOTI
SCOTI's Avatar
Re: Passed Smog
Texas has not tested emissions on vehicles 25yrs or older (as part of the inspections) for decades. It was 'Safety' only.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2025, 10:35 AM   #13
kglowacky
Re: Passed Smog
I meant to say Texas now doesn't even have a safety inspection on older vehicles. no inspection at all for anything kind.
Old 06-12-2025, 05:26 PM   #14
SCOTI
SCOTI's Avatar
Re: Passed Smog
Newer vehicles 2-24yrs old still require emissions testing (no check engine light w/proper drive cycle time).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
