Old 08-04-2025, 04:06 PM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
2/4 drop on 72 C10
What's the current consensus to get something like a 2/4 drop on my 72 C10? Looking to reduce a little bit of wheel gap and get a little better handling.
I know ECE use to make a 2/4 drop kit but they're long gone
I found a 2/4 drop kit on western chassis website.
I know about RideTech's street grip but I don't want to drop the truck that much or notch the frame
So what are folks thoughts??
picture for current stance
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 08-04-2025, 04:59 PM   #2
RustyPile
RustyPile's Avatar
Re: 2/4 drop on 72 C10
Dropped spindles in the front with stock springs. This doesn't effect the steering and suspension geometry.. Then for small amounts of lowering, go with either dropped springs or lowering blocks. Either way, 4 inches in the rear will probably require a frame notch..
Or you might use the approach I used on my truck.. Originally, it came with a 250 I6.. I installed a 454 BBC. Along with 2 1/2" dropped spindles and retaining the I6 front springs, the bumper is only 9" above the pavement. Retaining the 15" wheels and 3 inch lowering blocks in the rear give the truck a nice "Hot Rod Rake"..
RustyPile is offline   Reply With Quote
Old 08-06-2025, 01:52 PM   #3
scottofksu
scottofksu's Avatar
To maintain the focus on handling, I would suggest - as others have - drop spindles for the front. For the rear I would use 2" blocks and 2" shorter springs to maintain handling as much as possible (i.e., by retaining as much spring as possible).
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 08-06-2025, 04:16 PM   #4
67C10Step
67C10Step's Avatar
I did 2-1/2" drop spindles in the front with new stock height springs and progressive rate 4" drop springs in the rear.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
