Old 09-11-2019, 12:38 PM   #1
Dee27xpress
66 C10 Gas Pedal Scott's Rod's, Lokar????
I have searched around the forum for gas pedal ideas, what aftermarket (i.e. Lokar) pedals fit. If anyone has some pic's of what they have done I would really appreciate seeing them.
Also Anyone used the Scott's Rod pedal?? Looks awesome here is the link.
https://www.scottshotrods.com/cnc-bi...als-60-66-c10/
Dee27xpress is offline   Reply With Quote
Old 09-11-2019, 04:27 PM   #2
forestb
forestb's Avatar
Re: 66 C10 Gas Pedal Scott's Rod's, Lokar????
I got this one and it fits well (just the gas peddle). You will want to get the spacer. I got the standard size peddle but it is a little small. I would get the xl peddle if I had to do it over. You will also need to get there cable for it to work correctly. I don't have a photo of it in the truck right now.
forestb is offline   Reply With Quote
Old 09-11-2019, 04:38 PM   #3
oldtrux
oldtrux's Avatar
those scotts pedals are nice!!
i wonder why they don't make the clutch pedal.
lokar makes brake and clutch set,but only for 67-72 series.
oldtrux is offline   Reply With Quote
Old 09-13-2019, 12:34 PM   #4
Dee27xpress
Thanks guys! @Forestb, With the Lokar pedal and the spacer did everything mount up without having to fab anything yourself?
Old 09-13-2019, 12:44 PM   #5
forestb
forestb's Avatar
I didn't do the install but I am pretty sure all he had to do was drill all the holes in the firewall and fill in the holes from the old peddle.
Old 09-13-2019, 07:58 PM   #6
oldtrux
oldtrux's Avatar
emailed scotts and apparently clutch pedals are in the works!
can't wait.
Old 09-17-2019, 09:54 PM   #7
shsahs
shsahs's Avatar
I need a better mouse trap as well. All I keep seeing is $350 each
They do look nice! But for me to put my sole of my boot on to mash the gas that is a little extreme for me.
shsahs is offline   Reply With Quote
Old 09-17-2019, 10:10 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
Been using this lokar on mine for 6 years.
Old 09-17-2019, 10:26 PM   #9
slepysal
slepysal's Avatar
I hear you!! I went with a low buck Ebay Pedal ato replace my old spoon type.
Not as "pretty" as the scotts or lokar but easy on the wallet and works fine.
Name:  old throttle.jpg
Name:  new throttle.jpg
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-09-2025, 05:31 PM   #10
AcampoDave
AcampoDave's Avatar
Any chance of getting a photo of it in the truck now? I know it's been a few years but maybe you can oblige me with one or two.
AcampoDave is offline   Reply With Quote
Old 08-09-2025, 06:28 PM   #11
forestb
forestb's Avatar
I will try to get you a photo in the next couple of days
Old 08-09-2025, 06:46 PM   #12
AcampoDave
AcampoDave's Avatar
Great thanks. I think I'm going to install one when it cools down outside
Old 08-10-2025, 04:57 PM   #13
forestb
forestb's Avatar
All of the hardware that is inside the cab is covered in carpet. I tried to peal it back a little to get a photo but I couldnÂ’t without disrupting things too much. The last photo is inside the engine compartment. You can see the braided line that has the throttle cable and below it is the 2 bolts that hold the pedal pivot point to the fire wall.
Old 08-10-2025, 05:01 PM   #14
AcampoDave
AcampoDave's Avatar
Perfect thanks. The standard size looks good, but I can see how the XL would also fit well. Nice the way your carpet is welted around it.
Old 08-10-2025, 06:55 PM   #15
forestb
forestb's Avatar
It’s hard to tell from the photo but the gas pedal is probably about 3 inches lower than the brake pedal
Old 08-10-2025, 09:27 PM   #16
slepysal
slepysal's Avatar
For what it's worth my cheep ebay pedal is still going strong
Old 08-10-2025, 10:22 PM   #17
AcampoDave
AcampoDave's Avatar
6 years later thats good. My stock stuff still works but it's sloppy . The pedal has broken off the ball studs now and I'm just using the metal. I've read past posts from members who say the cable setup just feels better. I can imagine so, especially with a proper connection at the carb. (Which I don't exactly have either)
Old 08-13-2025, 10:36 AM   #18
1964FarmFreshC10
I was just planning to use one of the OEM pedal assemblies from a square body in my 64.
1964FarmFreshC10 is offline   Reply With Quote
Old 08-13-2025, 06:25 PM   #19
AcampoDave
AcampoDave's Avatar
I thought about that too but people say the angle is awkward. I guess they can can be modified, but junk squarebodies are getting rare. I figure that after I spend the time and fuel (California $) to track one down cable and all, pay for it, and then modify it to be comfortable I'd probably be better off just calling Lokar and spend a tad more for for a sweet piece of hardware delivered to my house.
Old 08-14-2025, 11:49 AM   #20
cwcarpenter98
cwcarpenter98's Avatar
I put one in my 63. It does work, but it was annoying to install. I had to put multiple bends in the arm to make it somewhat fit and I ended up only being able to use 2 mounting holes on the flat spot of the firewall instead of all three.
I’m planning on switching over to the 71-72 pedal during the rust repair process.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 08-14-2025, 01:43 PM   #21
1964FarmFreshC10
What's the difference? Visually the 71-21 and square body pedal assemblies look pretty much the same to me.
I only have a square body unit on hand and have only looked at picks of the 71-72.
Old 08-18-2025, 07:32 PM   #22
cwcarpenter98
The difference is in the way the arm is made. Check out Page 3 post #40 of my build thread for pictures. The arm comes down to the floor off the mount then kicks to the passenger side. The 71-72 arm just goes straight down from the bend off the mount
Christian Carpenter
Old 08-19-2025, 08:04 AM   #23
1964FarmFreshC10
Ahh ok thanks for the info.
