Old 08-30-2025, 06:00 PM   #1
GOPAPA
GOPAPA's Avatar
My truck is K10 and manual 4 speed trans
I am having problems shoving the clutch peddle to the floor so not to grind gears .. Any of you know of a factory or home made extention of 1 and half inch , maybe 2 inch something that can attached to the clutch peddle to fix my problem ?
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 08-31-2025, 12:19 PM   #2
Getter-Done
Getter-Done's Avatar
Re: My truck is K10 and manual 4 speed trans
Is this piece for the Adjustment worn?
Link below for reference.
Link:https://www.jegs.com/i/JEGS+Performa...01030/10002/-1
If that is worn along with the clutch pedal bushings and also the Z-bar bushings,
That would add up to a lot off slack in the system.
You may have already checked these things.
Just trying to help.
The early bird gets the worm,
85 Chevy K-20
Old 08-31-2025, 12:55 PM   #3
GOPAPA
GOPAPA's Avatar
Attachment 2430809
Thanks ,, that is an idea to check on.. that is if it can be adjusted to not make my clutch hit all the way to the floor board so to keep the gears from grinding ,, then, that would help me some and maybe a lot..
Old 08-31-2025, 01:55 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
I saw your other thread about the clutch bothering you. A hydraulic conversion wouldn't be cheap but might fix your problems.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-31-2025, 08:15 PM   #5
GOPAPA
GOPAPA's Avatar
Well ,, my leg is not going to grow longer so just maybe ?
Old 09-01-2025, 09:37 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
Attachment 2430809
x2. Check all this before throwing parts at it.
Old 09-03-2025, 03:27 PM   #7
GOPAPA
GOPAPA's Avatar
thanks .. I will do that
Old 09-29-2025, 11:12 PM   #8
c30
Active Member
c30's Avatar
You may have an issue with the fork as well.
c30 is offline   Reply With Quote
