Junior Member
![]() Join Date: Jan 2024
New 3D printed THROTTLE dash tabs - Custom option available
I am offering for sale new 3D printed THROTTLE dash tabs.
These are made using ABS and should last very well. I also have the REAR A/C and a new REAR HEAT tab available for a Suburban. I can also make a custom tab for you if you want a tidy factory looking tab to go with your custom switch. THROTTLE, REAR A/C, REAR HEAT tabs are $20 each. Custom tabs are $50 each - mainly to cover a portion of my time for this service. I fussed quite a bit with the design to try to get the same texture as the original tabs. This resulted in a two piece design that required some assembly and silver paint, and about 15 minutes for me to carefully assemble. I needed one of the hard to find tabs, so I decided to make my own. Since I already put in the time and effort on the design I have decided to offer these to others in need. Thanks Scot |
![]() Join Date: Dec 1999
Re: New 3D printed THROTTLE dash tabs - Custom option available
Cool, Nice work
Ron
Member #111 68 C-10 Daily Driver70 4x4 Project76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
I will take 3 throttle tabs how much mailed t Az 85203 and need info on how you need paid
![]() Join Date: Dec 2014
Great ingenuity, I love those.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
Junior Member
Junior Member
I forgot to mention in my original post what to expect for a timeline from me. I am not a business. I am quite busy these days with young kids and restoring my own 72 Suburban, so it might take a few days or even a week to reply to a post, but I will definitely reply to anyone interested in a tab. I usually make a post office run every 1-6 weeks so it might take a bit to get it shipped out to you, but once we have started the process I will keep you updated accordingly.
Thanks Scot |
![]() Join Date: Nov 2016
Scott will take a throttle tab. Thanks!
1987 V30 Silverado SRW 454/400 4x4 104k 1979 GMC C3500 Sierra Classic 3+3 454/4l80e 1971 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=804580 https://67-72chevytrucks.com/vboard/...d.php?t=837441 https://67-72chevytrucks.com/vboard/...92#post9355392 |
Active Member
![]() Join Date: Oct 2023
Just a thought , might want to make a tab that says CHOKE on it , the tab on my C 50 has a manual choke , and the tab is really loose on the shaft . Other folks may be interested in a choke tab . Good luck on all your projects.!!!
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck. 71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed. 22.5 Goodyear radial$ n Wheels Now rim$ 86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop |
Junior Member
#10 | |
Junior Member
Thanks Scot |
| Bookmarks |
| Tags |
| dash tab, label, throttle, throttle cable |
| Thread Tools | |
| Display Modes | |
