Old 12-17-2025, 12:14 PM   #1
moreroomforthekids
Junior Member
New 3D printed THROTTLE dash tabs - Custom option available
I am offering for sale new 3D printed THROTTLE dash tabs.
These are made using ABS and should last very well.
I also have the REAR A/C and a new REAR HEAT tab available for a Suburban.
I can also make a custom tab for you if you want a tidy factory looking tab to go with your custom switch.
THROTTLE, REAR A/C, REAR HEAT tabs are $20 each.
Custom tabs are $50 each - mainly to cover a portion of my time for this service.
I fussed quite a bit with the design to try to get the same texture as the original tabs. This resulted in a two piece design that required some assembly and silver paint, and about 15 minutes for me to carefully assemble. I needed one of the hard to find tabs, so I decided to make my own. Since I already put in the time and effort on the design I have decided to offer these to others in need.
Scot
moreroomforthekids is offline   Reply With Quote
Old 12-17-2025, 07:02 PM   #2
Husker
Husker's Avatar
Re: New 3D printed THROTTLE dash tabs - Custom option available
Cool, Nice work
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 12-17-2025, 10:16 PM   #3
67kid
I will take 3 throttle tabs how much mailed t Az 85203 and need info on how you need paid
67kid is offline   Reply With Quote
Old 12-17-2025, 10:56 PM   #4
dagnabbitt
dagnabbitt's Avatar
Great ingenuity, I love those.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 12-19-2025, 02:35 PM   #5
moreroomforthekids
Junior Member
67kid I will get those put together for you. Send me a PM and we can sort out the rest of the details.
Scot
Old 12-19-2025, 02:46 PM   #6
moreroomforthekids
Junior Member
I forgot to mention in my original post what to expect for a timeline from me. I am not a business. I am quite busy these days with young kids and restoring my own 72 Suburban, so it might take a few days or even a week to reply to a post, but I will definitely reply to anyone interested in a tab. I usually make a post office run every 1-6 weeks so it might take a bit to get it shipped out to you, but once we have started the process I will keep you updated accordingly.
Scot
Old 12-30-2025, 12:44 PM   #7
JT_Trucks87
JT_Trucks87's Avatar
Scott will take a throttle tab. Thanks!
1987 V30 Silverado SRW 454/400 4x4 104k
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
https://67-72chevytrucks.com/vboard/...92#post9355392
JT_Trucks87 is offline   Reply With Quote
Old 12-30-2025, 10:34 PM   #8
G-749
Active Member
Talking Re: New 3D printed THROTTLE dash tabs - Custom option available
Just a thought , might want to make a tab that says CHOKE on it , the tab on my C 50 has a manual choke , and the tab is really loose on the shaft . Other folks may be interested in a choke tab . Good luck on all your projects.!!!
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck.
71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed.
22.5 Goodyear radial$ n Wheels Now rim$
86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop
G-749 is offline   Reply With Quote
Old 01-02-2026, 07:26 PM   #9
moreroomforthekids
Junior Member
Perfect, you are in cue.
Send me a PM with your name and mailing address and I will get one coming to you.
Scot
Old 01-02-2026, 07:34 PM   #10
moreroomforthekids
Junior Member
Thanks for confirming about the CHOKE tab. No problem. I will build some CHOKE tabs. Please let me know if you'd like one. If so, send me a PM with your name and mailing address and I will put you in cue. If everything goes as planned.......I might be able to have one ready for you early next week.
Scot
dash tab, label, throttle, throttle cable
