Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-05-2025, 08:20 AM   #1
cag
Active Member
level garage floor????
looking for ideas to fix this floor, anything I can put over it to level it out? cracked and sinking in a few spots, thanks!
cag is offline   Reply With Quote
Old 12-06-2025, 03:22 PM   #2
Getter-Done
Getter-Done's Avatar
Re: level garage floor????
Depending on the situation of your floor and what caused it,
Will determine which approach you should take.
Also if you want to do this yourself is a big factor.
Which is what I hope to do.
I have one floor I need to fix a I have been looking into different solutions.
Again depending on the situation in no particular order.
Option #1
Option #2
Self leveling is most of the time not a Good solution.
Do it Yourself
Option #3
Raise the concrete from below before patching.
Do it yourself option.
Self leveling Epoxy.
The early bird gets the worm,
85 Chevy K-20
Old 12-06-2025, 04:51 PM   #3
truckster
truckster's Avatar
My opinion, having a similar situation, is that any repair that doesn't replace the original concrete is going to be temporary. Your mileage may vary.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 12-06-2025, 06:07 PM   #4
franken
I'd be concerned with why the problem exists or what's going on under the existing concrete.
Old 12-07-2025, 09:49 PM   #5
grumpyolddog
I am working on my garage space right now, and the first thing I had to do was fix the cracked and unlevel floor. The space is 22"x18", I have been here for ten years and the floor has not moved in that time. I had five and a half inches of cement poured over the old floor, I had to reframe the two garage and one man door. It was poured in July so time will tell of it will work out. The guys who did the work said they do this quite a bit. I just said it had to out last me.[IMG][IMG]20250722_145318.heic[/IMG][/IMG]
grumpyolddog is offline   Reply With Quote
Old 12-07-2025, 10:10 PM   #6
grumpyolddog
Not sure if I have this right for the pictures
Old 12-07-2025, 11:52 PM   #7
MySons68C20
MySons68C20's Avatar
That came out nice!
MySons68C20 is offline   Reply With Quote
Old 12-08-2025, 09:24 AM   #8
cag
Active Member
its a garage built in 72, floor cracked and few low spots, thanks for all the info!!
Old 12-08-2025, 10:31 AM   #9
Rickysnickers
Rickysnickers's Avatar
I flipped your pictures. Sorry, but I hate looking at crocked photos.
Old 12-24-2025, 09:23 AM   #10
c30
Active Member
c30's Avatar
Did a job in an old foundry about twenty years ago.
Floor was cracked and heaved all over.
We started with a rented floor grinder with diamond head. To knock down high spots.
We used a product from Sikka, which we bought at a local contractor supply.
It's a dry powder and I highly recommend using the latex additive when mixing.
Used a stiffer mix first for heavy fills and went back with a creamier mix for finishing and feathering.
It's still good to this day.
c30 is offline   Reply With Quote
Old 12-30-2025, 01:15 PM   #11
cag
Active Member
thanks!!
