Old 01-25-2026, 05:58 AM   #1
DBear
DBear's Avatar
Dana 60 Studs
Howdy,
When installing the 2 studs into a Dana 60 front axle spring perch, is it proper procedure to use loctite on the studs? If so, would it be red or blue? Thank you in advance.
DBear is offline   Reply With Quote
Old 01-25-2026, 09:21 AM   #2
b454rat
Re: Dana 60 Studs
i didn't use it, but guess wouldn't hurt, but don't think it would matter.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-25-2026, 12:46 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Re: Dana 60 Studs
I used blue on mine. It’s probably not necessary in all honestly though.
Tyler
57taskforce is online now   Reply With Quote
Old 01-26-2026, 04:18 PM   #4
Orange Crate
Orange Crate's Avatar
Re: Dana 60 Studs
I used blue also. Plus I added sealant around them at the top to try to prevent water ingress. I had a hell of a time getting them out when I rebuilt the axle. When I did get them out they were clearly on their way to becoming permanently rust seized. I tapped the holes to accept a 5/8-18 stud that I cut off of an unused U bolt. Now all my hardware for my axles is the same size and also the nuts.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
Old 01-27-2026, 02:14 PM   #5
kwmech
Re: Dana 60 Studs
No loctite needed. But the rust thing is real. I've actually put boat grease on the threads. Once it is torqued down it's all good. there has also been times the spring pack is too thick with aftermarket lift springs and I've just used a Grade 8 bolt with a flat and lock
